Finding sum of Power Series with Factorials
Finding the sum of a power series with factorials can be complex, especially when trying to relate it to geometric series. The Ratio Test can determine convergence but does not provide the sum itself; a converging series does not imply the sum equals zero. The Maclaurin series expansion for e^x is relevant, as it illustrates how to express series involving factorials. Understanding the relationship between the series and known expansions can aid in finding exact values. Exploring these concepts further can help clarify the approach to solving such problems.
PencilnPaper
I am confused about how to find a sum of a power series, especially when it contains factorials and I can't quite get it to look like a geometric series. Is it the same thing as finding a limit (and then I would follow the various tests for convergence of the different kinds of series)? Is it the same thing as finding an "exact value" (which I think means finding a function in terms of x)?
I can't give the exact problems I am working with because it is a take home test, but I hope if I make up an example, this will work for my general questions about the concept:
\sum \frac{(x)^n}{(n+1)!}
With one problem similar to above I am working with, when I did the ratio test it appears to converge to zero; does that mean the sum equals zero?
I am having a similar problem myself in the above thread, but I do know that if you use the Ratio Test, and the outcome is less than one(i.e. zero) then the series converges, however this is NOT the sum. Past that i can't help. Sorry!
dx said:
Do you know the infinite series of ex?
Look at my reply in this thread: https://www.physicsforums.com/showthread.php?t=313878
Thanks, but, YIKES! That link was exactly the same question as on our test. I didn't look at your response to that question because I don't want to get into any trouble. I've looked into three calculus books and none of them explain this concept well enough. I was hoping to get some help with the general idea and then I can figure out the problem myself, but I don't want you to have to work double time to answer the same questions.
Hi PencilnPaper,
If it's a take home test, I presume it's open book? If so, then I'm guessing it's ok for you to ask questions, as long as you don't ask any questions directly from your test.
If you're at all unsure of whether you're allowed to seek help, then I think it's best if you don't.
Think of the series as such:
\sum \frac{x^n}{n!(n+1)}
Now you know from the Maclaurin series expansion for e^x that the following is true:
\sum_{n=0}^{\infty} \frac{x^n}{n!} = e^x
This is true because e^x = 1 + x + \frac{x^2}{2!} + \frac{x^3}{3!} + \frac{x^4}{4!} + ...
Also note that e^x - 1 = x + \frac{x^2}{2!} + \frac{x^3}{3!} + \frac{x^4}{4!} + ...
Now the expansion of this original series is as follows: \sum_{n=0}^{\infty} \frac{x^n}{n!(n+1)} = 1 + \frac{x}{2*1!} + \frac{x^2}{3*2!} + \frac{x^3}{4*3!} + \frac{x^4}{5*4!} + ...
Subtract the first term (i.e. 1) from the expansion:
[\sum_{n=0}^{\infty} \frac{x^n}{n!(n+1)}] - 1 = \frac{x}{2*1!} + \frac{x^2}{3*2!} + \frac{x^3}{4*3!} + \frac{x^4}{5*4!} + ...
I'll put two particular results together:
[\sum_{n=1}^{\infty} \frac{x^n}{n!(n+1)}] = \frac{x}{2*1!} + \frac{x^2}{3*2!} + \frac{x^3}{4*3!} + \frac{x^4}{5*4!} + ...
Unfortunately, I don't know how to progress from here - I'm only in year 12, but maybe these ideas would help?
Ulagatin
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 22 ·
  • · Replies 38 ·
