Sum of a power series in terms of x
10 replies · 10K views
OrbsAndSuch
Hello, I need to find the sum(as a function of x) of the power series [tex]\Sigma^{\infty}_{n=0}\frac{(x+1)^n}{(n+2)!}[/tex]
The hint i was given was compare it to the Taylor series expansion of ex.
Im not sure even how to start this problem and any help is much appreciated.
jbunniii said:
Do you know this series?
[tex]\sum_{n=0}^{\infty} \frac{x^n}{n!}[/tex]
yes, that's the expansion for ex. Its the (n+2)! in the original problem that's confusing me.
ok i factored and came up with:
[tex] <br /> \frac{1}{(x+1)^2} \sum_2^\infty \frac{(x+1)^n}{n!} <br /> [/tex]
Do the indices matter? If not then it becomes
[tex]\frac{e^{x+1}}{(x+1)^2}[/tex]
The indices (you should call them limits) do matter. What two terms do you have to add to
[tex]\sum_2^\infty \frac{(x+1)^n}{n!}[/tex]
to make it equal to ex+1?
I would have to add the first two terms of the sum if the limits started at 0 which would be
1 + (x+1)
[tex] <br /> 1 + (x+1) + \frac{e^{x+1}}{(x+1)^2}<br /> [/tex]?
Yes, the first two terms. But your answer is not correct.
[tex]1 + (1 + x) + \sum_2^\infty \frac{(x+1)^n}{n!} = e^{x+1}[/tex]
This means
[tex]\sum_2^\infty \frac{(x+1)^n}{n!} = e^{x+1} - 2 - x[/tex]
Substitute this back in
[tex]\frac{1}{(x+1)^2} \sum_2^\infty \frac{(x+1)^n}{n!}[/tex]
[tex] <br /> \frac{e^{x+1} - x - 2}{(x+1)^2}<br /> [/tex]
yes?
