Finding tangent line that passes through a point not on curve
The discussion revolves around finding the tangent lines to the curve y=3x/(x-2) that pass through the point (-1,9). The initial steps involve deriving the equation of the tangent lines and forming a quadratic equation to determine the points of contact. The discriminant of this quadratic is analyzed to confirm that there are two tangents, leading to slopes of m=-2/3 and m=6. Participants emphasize the importance of using derivatives to simplify the problem and clarify the relationship between the roots of the discriminant and the slopes of the tangent lines. Ultimately, understanding this relationship aids in solving for the tangent lines without extensive calculus.
kwal0203
Find the number of tangent lines to the curve:
y=\frac{3x}{x-2}
which pass through the point (-1,9). Find also the points of contact of these tangent lines with the curve.
1. I found the equation of lines passing through (-1,9) -> y=(x+1)m+9
2. I thought there must be a contact point between the line through (-1,9) and the original equation so -> \frac{3x}{x-2}=(x+1)m+9
3. I put this into a quadratic form -> mx^{2}+(6-m)x-2m-18=0
4. I checked the discriminant of the equation in '3' -> 9m^{2}+60m+36
5. I found the roots of '4' to be x=6 and x=-\frac{2}{3} edit: m=6 and m=-\frac{2}{3}
I know that if the discriminant is 0 then there is one real solution. This means that there are two tangents of the original equation that also go through (-1,9).
Now I don't know how to get the equation for these two tangent lines? How can I use the roots of the discriminant to get these equations?
Any help appreciated!
m is the slope. Why are you treating that as an unknown? That's the derivative dy/dx, yes? Put that it. The only real unknown here is x.
Not sure I'm following what your saying. Do you mean that the roots of the discriminant i.e. X=6 and -2/3 are the slopes of the tangent lines I am looking for?
I really don't know, you went off track a bit for me after step 2). Just put dy/dx in for m in step 2) and try to solve for x. That would be a correct thing to do, yes? dy/dx=m. The only real variable here is x.
so you mean put in:
m=\frac{-6}{(x-2)^{2}}
kwal0203 said:
so you mean put in:
Indeed I do. Any reason why not?
\frac{3x}{x-2}=\frac{(-6)(x+1)}{(x-2)(x-2)}+9
3x=\frac{(-6)(x+1)(x-2)}{(x-2)(x-2)}+9(x-2)
x=\frac{(-6)(x+1)(x-2)}{(3)(x-2)(x-2)}+\frac{9}{3}(x-2)
x=\frac{(-6)(x+1)}{(3)(x-2)}+3(x-2)
x=\frac{(-2)(x+1)}{(x-2)}+3(x-2)
x=\frac{-2x-2}{(x-2)}+3(x-2)
Cant seem to solve for X am I doing something wrong?
Why don't you multiply by (x-2)^2 to begin with? You'll just get a quadratic equation to solve.
Oh right like this... what is the next step?
3(x-2)^{2}-x(x-2)-2x-2=0
2x^{2}-12x+10=0
2(x^{2}-6x+5)
2(x-1)(x-5)
so x=1,5?
If you did that right, then multiply it out and solve the quadratic. If you didn't do it right then fix what's wrong and do it correctly. I'm too tired to check it right now. Good luck!
kwal0203 said:
2x^{2}-12x+10=0
2(x^{2}-6x+5)
2(x-1)(x-5)
so x=1,5?
Yes, x=1,5. Then you can use the x values to find m. So you have your two tangent lines.
Great thanks Dick
kwal0203 said:
Great thanks Dick
Oh wow the slopes of the tangents turn out to be:
m=-2/3 and m=6
Just as in the beginning!
I.e. the roots of the discriminant
m=-2/3 and m=6
Ok, that's good. You did understand the problem. I just took the more direct approach of eliminating m and then not looking at anything after that. Feel good?
Yep lol. But I don't really understand why the root of the discriminant is the slope of the tangent line as a concept.
It's because the tangent line intersects the curve exactly once. It's a trick to find tangent slopes without using calculus or derivatives. But I know you do know derivatives. It's a bit more straightforward if you use that.
