Finding tension in a wire between two charged objects
1 reply · 4K views · last reply
NickPA
Problem Statement:
Attached in pic. Find the tension between the wire of two charges.
My attempt: So basically idk how to account for tension and thought you can just use the E-Force between the two charges in the direction towards the E-Field. How do i account for the tension? In which direction should the tension force point?
Thanks
  • Diagram of two point charges, -6.50 μC on the left and 8.75 μC on the right, joined by a wire 2.50 cm long, with a uniform electric field E pointing to the right above the wire.
Try drawing a free body diagram for the negative charge. What forces are going to be acting on it? The tension is the force in the wire, which transmits a mechanic force between the positive and negative charges (in addition to the electric force which is due to the electric field).
