Finding the Center of Mass of a pendulum
To find the center of mass of a pendulum system with two balls and a cord, the center of mass is influenced more by the heavier lower ball. The approach involves calculating the center of mass for the balls first, with the understanding that the center of mass of the cord is typically located at its midpoint. The relevant equation for determining the center of mass is the weighted average of the positions of the masses. Balancing the system conceptually helps identify the center of mass, as it should be closer to the heavier components. The discussion emphasizes the importance of understanding the distribution of mass in the system.
antigen123
Assuming that the combined mass of the balls is greater than the combined mass of the cords, but that the cords do have some mass, where is the center of mass for the system shown below?
None
I tried approaching this problem by finding the center of mass for the two balls first. I picked a point closer to the lower ball which is heavier. However I don't know how I would find the center of mass of the cord?? Is the center of mass usually closer to heavier objects. I think I need a conceptual understanding of the center of mass.
well, write down the relevant equation !
The pragmatic one is: where do you support something to get a balance ? Good for individual sticks and balls. For a rope with weight: imagine it's frozen.
Likes 1 person
My book did not give an equation for solving this particular question. However I do like the idea of finding a balance in the object in order to find the center of mass. Thanks!
The relevant equation for the position of the center of mass is
$$\vec r_{\rm c.o.m.} = {\sum_i m_i \, \vec r_i \over \sum_i m_i }$$check it out.
For each ball you end up in the center of the thing and for each section of rope you end up halfway. Comes naturally. Adding the four vectors according to the relevant formula can never let you end up at a (why not?) or at b (why not?) and some judgment about M2 > M1 leaves only one answer.
  • · Replies 25 ·
