Finding the change in length of a nylon string
The discussion focuses on calculating the change in length of a nylon tennis string under a tension of 225 N, with a diameter of 0.97 mm and an initial length of 29.6 cm. The relevant formula used is ΔL = (F * L) / (A * E), where E is Young's Modulus for Nylon, valued at 5 x 109 N/m2. After several attempts, the correct change in length is determined to be approximately 1.8025 cm, confirming that the previous calculations yielding significantly smaller values were incorrect.
  • Understanding of Young's Modulus and its application in material science
  • Familiarity with basic physics equations involving tension and area
  • Knowledge of unit conversions, particularly between meters and centimeters
  • Ability to perform algebraic manipulations in physics equations
  • Study the derivation and application of Young's Modulus in different materials
  • Learn about the significance of cross-sectional area in tensile strength calculations
  • Explore unit conversion techniques in physics to avoid common pitfalls
  • Practice solving similar problems involving tension and elongation in various materials
Students in physics or engineering courses, particularly those focusing on material properties and mechanics, as well as educators looking for practical examples of tensile stress calculations.
tjohn101
A nylon tennis string on a racket is under a tension of 225 N. If its diameter is 0.97 mm, by how much is it lengthened from its untensioned length of 29.6 cm?
Li= 29.6cm =.296 m
r= 4.85e-4 m
A= 7.389811319e-7
F= 225 N
E= Young's Modulus for Nylon= 5 x 10^9
Solving for deltaL
A=pi(r)^2
F= E (delta L/Li) A
I've found the area and tried using the equation above but did not get a correct answer. I may well have messed up the calculations because that equation confuses me a little and I seem to be algebraically challenged this fine morning.
All my incorrect answers so far are:
14.5e-8 cm
7.470483757e-8 cm
14.506204362e-7 cm
7.470483757e-6 cm (the last three answers came from the equation above)
Any help is greatly appreciated! Thank you!
\Delta L = \frac{FL}{AE}
what units are E in?
I've been trying to find the equation in latex... :/ E is in N/m^2.
I was just checking to see what units the value of E you quoted were in.
But try plugging the number back in and checking again, you aren't supposed to get such small changes in length.
Okay I plugged everything into it and got an answer but I need to be sure it's right. I only have one more try. :/ Would the answer be 1.802481745?
PS: I love your signature. Makes everything so much simpler. : )
If you mean 1.8025 cm, then I believe so as that looks better than 14.506204362x10-7 cm
Where did that answer come from? And sorry about the long numbers. My homework website is extremely picky
1.802481745 what unit is this in?
for the other number, I just quoted one of your above answers.
Centimeters. The final answer is supposed to be in centimeters so I multiplied the answer from the equation by 100.
Oh yeah I forgot about that one. :/ That was early this morning.
then 1.802481745cm should be it.
That it is! Thank you very much for your help, sir.
42K
  • · Replies 75 ·
