Finding the Closed Form of a Summation for k*z-k: Step-by-Step Solution
  • Thread starter Thread starter air-man001
The discussion revolves around finding the closed form of a summation involving the expression k*z-k, specifically the infinite series starting from k=0. The original poster seeks assistance in deriving this closed form step-by-step.
  • Participants explore the nature of the summation and its relation to geometric series. Some suggest starting the sum at k=1 and consider the implications of treating z as 1/x. There are discussions about the derivative of series and the challenges of identifying a fixed common ratio in the terms of the series.
Participants have provided hints and alternative directions for approaching the problem, particularly regarding the use of derivatives and geometric series. There is an ongoing exchange of ideas, with some expressing confusion about the hints given and others encouraging further exploration of the concepts involved.
Some participants clarify that the discussion is related to studying for an exam in Digital Signal Processing, rather than a typical homework assignment. This context influences the nature of the assistance sought and provided.
air-man001
Please please, I need solution
hello every one
I have this summation in my book
infinity
\sum k*z-k
k=0
my solution:
infinity
\sum k*z-k = z-1+2z-2+3z-3+...
k=0
please i want the closed form (step-by-step)
Here's a hint. The sum might as well start at k = 1. Let z = 1/x
\sum_{k=1}^n kx^k = x\sum_{k=1}^n kx^{k-1}
What is inside the sum on the right you should recognize as a derivative of a series that you should be able to sum. Can you take it from there?
LCKurtz , i can't understand your post.I know the closed form of geometric series =\frac{FirstTerm} {1 - CommonRatio}
CommonRatio = termn / termn-1
but in my problem , the 'CommonRatio' isn't fixed
term4/term3 not equal to term3/term2
Which should suggest to you that your series isn't a geometric series and you're heading down the wrong path. LCKurtz has given you an alternative direction, so see what you can do with that.
Do you understand the part of my hint about
<br /> \sum_{k=1}^n kx^{k-1}<br />
being the derivative of something?
LCKurtz
it is derivative of xk
right?
mr Mark44
I am studying "z-transform" in Digital Signal Processing,
this is not homework, i studying for final Exam tomorrow
air-man001 said:
LCKurtz
right?
Yes, so you have a sum of derivatives. That is the same as the derivative of the sum and you should be able to calculate that sum and take its derivative.
thank you mr.LCKurtz
I will try it now
i can't do it!
You have
<br /> \sum_{k=1}^n kx^k = x\sum_{k=1}^n kx^{k-1}= x\frac{d}{dx} <br /> \left (\sum_{k=1}^n x^k\right )<br />
You know the formula for the sum of the geometric series. Use it and do the derivative.
I'm sorry:mad:
i can't do it!:cry::cry::cry:
air-man001 said:
I'm sorry:mad:
Get out your algebra book and look up the formula for the sum of the first n terms of a geometric series and use it to evaluate the sum.
Then take its derivative. I'm not going to do it for you.
Firstly..Thank you for help me.
secondly.. this is not homework ... the subject in Digital signal processing (finding the z-transform) only.
i will save the issue rather than understanding
air-man001 said:
mr Mark44
Whether it's homework of exam review, we're not going to do your work for you. We'll help you do it and steer you in the right direction if/when you make a mistake, but you have to put in some of the effort.
  • · Replies 16 ·
