Finding the Coefficient of Friction in a Spring-Block Incline System
  • Thread starter Thread starter Puneet Tanwar
    Work Work done
The discussion focuses on calculating the coefficient of friction in a spring-block incline system involving a 1 kg block and a spring with a spring constant of 100 N/m. The block moves 10 cm down the incline before coming to rest, leading to the equation mg(sin θ - µ cos θ) = kx. The initial assumption of using equilibrium conditions without considering work done was incorrect, as the friction force acts as a reaction force only when the block is at rest. The correct approach involves understanding that the block's stopping position is determined by the balance of forces, specifically kx = mg sin θ.
  • Understanding of Newton's laws of motion
  • Knowledge of spring mechanics and Hooke's Law
  • Familiarity with friction concepts and coefficients
  • Basic trigonometry related to inclined planes
  • Study the principles of Hooke's Law and its applications in mechanics
  • Learn about the dynamics of friction on inclined planes
  • Explore energy conservation methods in spring-block systems
  • Investigate the effects of different spring constants on motion and equilibrium
Students and professionals in physics, mechanical engineering, and anyone interested in understanding the dynamics of spring-block systems and frictional forces on inclines.
Puneet Tanwar
Moved from technical forum, so no template
Hi - I'm looking for some help with the solution of this problem
"A 1 kg block situated on a rough incline is connected to a spring with spring constant 100 Nm-1 as shown in Figure. The block is released from rest with the spring in the unstretched position. The block moves 10 cm down the incline before coming to rest. Find the coefficient of friction between the block and the incline. Assume that the spring has negligible mass and the pulley is friction less."
The solution given is :
I tried to solve the problem based on the final equilibrium state - without calculating the work done. The equations I end up with are:
Block: mg sin θ = µ mg cos θ + T
Spring end: T = kx
Leading to : mg (sin θ - µ cos θ) = kx
This is off by factor of 2 compared to the solution above.
What's the right approach to solve the problem?
Unfortunately, that's a wrong assumption in this scenario. The friction force is a reaction force. Imagine ##\mu## to have exactely a value, so that the block stops at a position ##x## for which ##kx=mg\;sin \theta##. Then the two forces are in equilibrium, the block does not move and no friction force is acting on it. Therefore your approach in this case is not applicable.
Understood. Thanks!
  • · Replies 27 ·
11K
  • · Replies 58 ·
