Finding the components of this velocity vector
The problem involves determining the x- and y-components of a velocity vector with a magnitude of 100.0 m/s that makes an angle of 160° with the positive x-axis. The subject area pertains to vector decomposition and trigonometry.
  • Participants discuss the correct interpretation of the angle in relation to the x-axis and its implications for the vector's components. There are attempts to clarify the sketch and the quadrant in which the vector lies. Questions arise about the angle measurement and its effect on the x- and y-coordinates.
The discussion is ongoing, with participants providing guidance on the correct interpretation of angles in the Cartesian plane. There is a recognition of confusion regarding the quadrant and the implications of the angle measurement, but no consensus has been reached on the final components.
Some participants express uncertainty about the angle's measurement direction and its relationship to the positive x-axis, leading to potential misinterpretations of the vector's position in the coordinate system.
PleaseAnswerOnegai
A velocity vector has magnitude 100.0 m/s and make an angle of 160° with the positive x-axis. Determine the x- and y-components of the vector.
Trig functions
PleaseAnswerOnegai said:
Homework Statement:: A velocity vector has magnitude 100.0 m/s and make an angle of 160° with the positive x-axis. Determine the x- and y-components of the vector.
Relevant Equations:: Trig functions
Welcome to PhysicsForums. :smile:
That sketch looks wrong. What line is 180 degrees from the x-axis? So 160 degrees would be pretty close to that line, not vertical like that...
Just started Physics and I wasn't sure if my answer and solution was right. I attempted to project it on the cartesian plane based on my understanding. It said "an angle of 160 with the positive x-axis." What I understood from this is that angles of the triangle that makes contact to the x-axis equal to 160 so I assumed the angles would be 70 and 90.
Hi! What would the correct sketch look like? While I was sketching it I knew something was fishy and I just had to ask hahaha
No, usually the angle is measured counterclockwise from the horizontal x-axis. So an angle of 90 degrees is straight up (along the y-axis), and an angle of 180 degrees is pointing left along the -x-axis. So where would 160 degrees counterclockwise from the x-axis be? And what would the x- and y- components of that vector be then?
So it would then be on the 2nd Quadrant, correct? What confused me was the usage of "positive x-axis" so I wrongfully assumed that it would be strictly in the 1st Quadrant (where x values are positive). I will solve it and send my answer! :)
Is the angle ##20°## or ##160°##? Is the x-coordinate positive or negative?
It's true that ##\sin(\pi-x)=\sin x##, but ##\cos(\pi-x)=-\cos x##, not ##\cos x##.
