Finding the constant and evaluating an integral with sin(2t)
  • Thread starter Thread starter Chewy0087
    Integration
9 replies · 2K views · last reply
Chewy0087
there are a number of things I've had trouble with here,
the first part i got fine, bieng;
y^2 = 4x^2 ( 9 - x^2) , which is correct according to the answers, next
the 'show that' question, now i had no problem getting it into the right form using the;
[tex]\int f(t)\frac{dx}{dt}dt[/tex] rule, so i put it in like so;
f(t) = 9 sin (2t) and [tex]\frac{dx}{dt}[/tex] = -3 sin t,
so i put them together to get, [tex]\int -27 sin(2t) sin(t)[/tex] , so A, the constant, would be minus 27...wrong! it simply says 27 in the back, so i thought, hey well maybe it's just an error, but i have a sneaking suspicion i might be wrong as well so i would appreciate clarification on that one aswell.
next, "find the value of this integral".
i don't know but this is a hard, hard integral, and we havn't even covered integration by parts or any formal integration aside from the [tex]\frac{n^(n+1)}{n+1}[/tex] stuff, I have however done "some" differential equations in my own time and am somewhat familiar with integration, i can wade my way through it sometimes however this one strikes me as very hard, i thought, well maybe i can break down the sin (2t), giving me,
[tex]\int cos(t) - (cos(t))^3[/tex] however from here I am also stumped...
also, it says to integrate between [tex]\frac{\pi}{2}[/tex] and 0, why [tex]\frac{\pi}{2}[/tex] i wonder? intuitiveley i looked at the equation and expanded the 9 - x^2 showing that the roots were x = 3 & x = -3, so if you put 3 (clearly) into the x equation to work out the value for t, 3 = 3 cos (t) -> 1 = cos (t) t = 0, 2[tex]/pi[tex], so why [tex]\frac{\pi}{2}[/tex]?<br /> <br /> i would be much obliged if someone could give some advice on this one!<br /> <br /> however i did look up the answer for this so as to complete the next part of the question, which was 18, and was able to do the last question<br /> <br /> thanks guys i realize it's a long question but i think it's just me and it might only take someone good at maths 2 minutes :P, sorry again for the huge post and thank you[/tex][/tex]
Well it looks to me that the -ve sign would say that you re finding the area of the opposite side that is shaded (the part under the x-axis)
For the integral try using sin2t=2sintcost and then using a u substitution
For the second one, note that it is actually
[tex] \int f(t) \left|\frac{dx}{dt}\right| dt.[/tex]
Geometrically it also makes sense that A > 0: the integral has a geometrical meaning as surface, which is always positive.
For the third question, you might find it helpful that
[tex]\sin(2t) = 2 \sin(t) \cos(t)[/tex]
and use a substitution of variables.
(If the latter doesn't mean anything to you: try writing the integrand as a derivative f'(t) of some function f(t)).
By compound angle formula, (sin 2t)(sin t) = 1/2 ( cos (t) - cos (3t) ). That's an easily integrable form
hmm thanks a lot for the clearing up on the 2nd and 3rd question however I'm still wondering about the integrating between
pi/2 and 0 has come from, as on the x-axis you're integrating between 3 & 0, meaning 2pi and 0 for t...
For t = 0, the curve passes through (x, y) = (3, 0) and runs counter-clockwise. The upper integration limit is the time instant where it passes through the origin. When you solve for x = 0, y = 0, you will find that the first solution is t = pi / 2 (remember, you only need to integrate over the time interval in which the curve encloses the shaded area).
Chewy0087 said:
hmm thanks a lot for the clearing up on the 2nd and 3rd question however I'm still wondering about the integrating between pi/2 and 0 has come from, as on the x-axis you're integrating between 3 & 0, meaning 2pi and 0 for t...
x = 3 cos t adopts the range of 0 to 3 for t having a range of 0 to pi/2. While other ranges appear to satisfy this condition, we must ensure that y= 9 sin 2t must be positive in that range of t chosen as well.
Ahh i see, so the 'origin' for t is actually (3,0) ? :OO
is that a general rule for all parametric forms - finding out the (x,y) when it's 0 and integrating FROM that point?
much obliged, this assistance is top quality
No. In principle, what you want to do is calculate the area under a part of the curve [itex]y^2 = f(x)[/itex]. You need to find out which part that is. When you plug in t = 0 in the equation, you get (x, y) = (3, 0), which is the point all the way on the right on the x-axis. When you look at the shaded area, you see that you have to integrate up to the point where the graph crosses the x-axis (which, in this case, happens to be the origin). So you need to find which t belongs to this point. I suggest you do the calculation yourself and check that it gives t = pi / 2.
that's great, much obliged sir
