Finding the currents in this circuit (2 voltage sources and 3 resistors)
The discussion revolves around solving a circuit with two voltage sources and three resistors using Kirchhoff's laws. Initial calculations for the currents I1, I2, and I3 were incorrect due to a misinterpretation of the circuit diagram. A revised approach involves substituting variables and setting up a new system of equations, leading to corrected values for the currents. The importance of accurately defining the loop direction and voltage contributions is emphasized, particularly regarding the relationship between the voltage sources. The conclusion drawn is that the orientation of U1 indicates it acts as a load rather than a source, given the negative current flow through it.
Nat1234123
Which current ratings do I1, I2 and I3 have if the resistances hold R1 = 0.1 ohm, R2 = 0.02 Ohm and R3 = 0.2 Ohm?
U = IR
1/R = 1/R_1 + 1/R_2 + ....
I1 = I2 + I3
In my attempt, I tried
1) I1 = I2 + I3
Then set up these two equations based on Kirchhoff's second rule:
2) U1 = R1 (I2) + R3 (I3) and
3) U1 + U2 = R1 (I1) + R2 (I3).
From what we have
10 = 0.1* I_2 + 0.2 * I_3
22 = 0.1* I_2 + 0.02*I_3
I_3 = 50 - 0.5 I_2
That means
I_2 = 233.3 A
I_3 = -66.7A
I1 = 166.6A
My answer is completely off.
1) I1 = I2 + I3
That does not comport with your drawing.
If I fix that part, will the rest be right then?
No. Start there and rework the problem.
Substitute I3=z, I2=y and I1=x.
System of equations:
z = y + x
12−0.2z−0.02x=0
−10+0.2z+0.1y=0
From second and third equation solve:
x=−10z+600
y=100−2z
Add these to the first:
z=(100−2z)+(−10z+600)
z=700/13
z~53,85
Thus I3~53,85 , I2~-7,7 and I1~61,5
Hope this helps!
z = y + x
12−0.2z−0.02x=0
−10+0.2z+0.1y=0
Hope this helps!
Your second loop equation (the last equation I quoted above) is incorrect. Which direction around the loop did you use?
How come? Clockwise, i.e. U2 is positive direction and U1 is negative direction.
Previously I quoted the following from your Post #5.
z = y + x
12−0.2z−0.02x=0
−10+0.2z+0.1y=0
The loop equation I referred to is:
##\displaystyle \quad −10+0.2z+0.1y=0 \ ##.
You are correct in that going clockwise around the outer loop the voltage contribution from ##U_1## is ##-\,10## volts. However, the clockwise direction around this loop is also consistent with the given choice of current direction for both ##I_2## and ##I_3##, so both give voltage drops (negative) across their respective resistors. In other words that loop equation should be:
##\displaystyle \quad -U_1-I_3 R_3 - I_2 R_1 = 0## .Your other equations are correct.
So basically higher voltage U2 is "charging" lower voltage U1 since given the orientation of U1 the current is reversed! Agreed!
I wouldn't put it that way, because you will find out that ##I_2## (which you relabeled as y) is negative, so the current flows through ##U_1## from the negative terminal to the positive terminal, opposite the direction chosen for ##I_2## in your drawing.
But after calculus one will find out I1 to be the largest and not I3, thus U1 has to be a load and not a source?
