Finding the Degree of of triangle.
  • Thread starter Thread starter anto3232
    Degree Triangle
To determine the launch angle of a water balloon using the provided quadratic equations for X and Y values over time, the user initially assumed that the lengths corresponding to these equations could indicate a 45-degree angle if they were equal. However, upon calculating, the user found that the X value (55.81) and Y value (52.62) are not equal, suggesting the angle is not 45 degrees. The discussion includes confusion about the application of the sine function, the relevance of converting values to percentages, and the need for clarity on how to derive the triangle's sides from the quadratic equations. Ultimately, the user seeks guidance on calculating the launch angle based on the coordinates of the water balloon's launch.
anto3232
I have to find the degree at which I am launching a water balloon and i have 2 quadratic formulas for the X and Y values versus time. The X and Y quadratic formulas for it was, X: 55.81t^2+(-2.197t)+0.5222
Y:52.62t^2+(-2.358t)+.4135
Is A the length of x or y, and for 45 degrees shouldn't it be equal? for it to equal 45 degrees?
Well i used a^2+b^2=C^2 and got 76.70, then i figured the angle of that side was 90 degrees so i set Sin (90)/76.70=sin (b)/52.62
and got .61 so i converted to % which is 61% but looking at the graph it didnt make much sense seeing as the length of A is greater than the Heigh (b) so wouldn't angle B, be smaller ?
This space is for relevant equations, not questions. Anyway, how do you know that the balloon was launched at an angle of 45 degrees?
For what, c? And what did you use for a and b?
and got .61
For what? Help us out here. Is this sin(b)?
anto3232 said:
so i converted to %
Why did you do that? I have no idea why you'd want to convert to a percent.
You need to show us how you got sides a and b of your triangle.
Thats what I am trying to figure out, I am pretty sure it didnt because for my y graph i got 52.62 and for the x graph i got 55.81 which isn't equal meaning it aint 45 Degrees, so what I am trying to say is since i know the a and b how do i figure out the angle?
a=the x which is 55.81 and b= the y which is 52.62.
Well i thought A for some reason was the 55.81 and B was the 52.62 from the two quadratic formulas, but i think that isn't right...
Hmm hold on ill let me take a look at what I am doing
okay so i have a water balloon launcher, it starts off at 0.51410733857,0.404340993843
and at the end of the launch its at 1.2249085093,1.03940105622, this is in meters btw..
What i need to do is find the angle or degree it launch's at. Do i X2-X1/Y2-Y1 it? I don't know that would just give me the slope but could that help me get the angle?
What's the exact wording of the problem? It seems like the problem as you first described it is different from what you have now. Where did the quadratic equations come from?
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
