Finding the Domain of a Trigonometric Function
6 replies · 2K views
Astraithious
Find the domain of this function and check with your graphing calculator:
f(x)=(1+cosx)/(1-cos2x)
i get to (1+cosx)/(1+cosx)(1-cosx) which is factored. so then setting each one to zero one at a time i figure out that
cosx = -1 and cosx = 1
then i get stuck from there.
here is what the page says to do Step 4
Setting each of those factors to zero, we get:
and
Step 5
Solving each of those, we get:
and
, where n is an integer
Step 6
Combining those, we get:
Step 7
Since those values are where the denominator is zero, our domain is at every value EXCEPT those:
, where n is an integerI was hoping somebody could break down the steps after 4 , i have no clue where
OR
come from, thank you
here is what the page says to doStep 4
and
Step 5
and
Step 6
Step 7
OR
You mean you don't know for which angles the cosine function is ±1 ?
Haven't you ever seen a graph of cosine (x) plotted out:
and
Step 5
and
Step 6
Step 7
OR
Really? You don't know what are the ##\cos## values of ##0## or or ##\pi = 180^{o}## or of ##2 \pi = 360^{o}##? You don't need a calculator to tell you those values; just draw a unit circle and use the geometric definition of ##\cos(\theta)##.
Cos(a) = 1
<=> Cos(a) = cos(0)
<=> a = n2π
n ∈ Z (integer numbers)
Same for cos(a) = -1
In general: cos(x) = cos(z) <=> x = z +n2π or x= -z + n2π
I would NOT do that factoring and canceling because [itex]\frac{1-x}{(1-x)(1+ x)}[/itex] and [itex]\frac{1}{1+ x)}[/itex] do NOT have the same domain. The first, [itex]\frac{1-x}{(1-x)(1+ x}[/itex], has domain "all real numbers except x= 1 and x= -1" while the second, [itex]\frac{1}{1+ x}[/itex], has domain "all real numbers except x= -1".
Instead, I would use the fact that [itex]1- cos^2(x)= sin^2(x)[/itex] so that [itex]\frac{1+ cos(x)}{1- cos^2(x)}= \frac{1+ cos(x)}{sin^2(x)}[/itex]. That is defined for all x except those such that sin(x)= 0.
Nobody is cancelling anything in this thread.
Using this method, wouldn't that leave us with [itex]\frac{2}{0}[/itex] or the indeterminate form [itex]\frac{0}{0}[/itex] given [itex]x=n\pi \quad \forall \quad n \in \mathbb{Z}[/itex]?
I also echo Ray Vickson's concern about remembering those trig values. It took me a while to get it, but it shouldn't be that hard to remember.
