Finding the E-field between two infinite plane charged sheets
10 replies · 16K views · last reply
aximwolf
Two infinite-plane non-conducting, thin sheets of uniform surface charge p1 = 13.35 uC/m2 and p2 = -8.65 uC/m2) are parallel to each other and d = 0.245 m apart. (As shown in the diagram below.) What is the electric field between the sheets? (Note: the field is positive if it is parallel to the vector x).
Diagram of two parallel, infinite-plane thin sheets of charge: left sheet labelled σ2, right sheet labelled σ1, separated by distance d. Point A sits to the right; a unit vector x̂ points right, perpendicular to the plates.
Sigma/2*epsilon_not
Epsilon not = 8.85e-12 (SI Units)
The distance between the sheets should not matter in calculating the E-field between them because the E-field between them is uniform. We are given two sigmas and since the net charge on the field is toward the negative plane we just sum the two over 2*epsilon_not, and Epsilon not is a constant.
sigma1=13.35e-6 C/m^2
sigma2=-8.65e-6 C/m^2
(sigma1 + sigma2)/(2*epsilon_not) = E-field
(13.35e-6 + 8.65e-6)/(2*epsilon_not) = 1.2e6 N/C
Than since the E-field is perpendicular to the planes, but pointing in the opposite direction of positive X the answer becomes negative.
Answer: -1.2e6 N/C (unfortunately I tried this and did not get the problem right)
What did I get wrong?
In the region between the sheets:
What is the direction of the E field due to the σ1 sheet?
What is the direction of the E field due to the σ2 sheet?​
The E-field on sigma1 is going -x and so is sigma2 right?
aximwolf said:
The E-field [STRIKE]on[/STRIKE] due to sigma1 is going -x and so is sigma2 right?
Right, so you should have a negative plus a negative.
Right but that doesn't change the answer numerically am I forgetting a step?
Why did you express your answer to only 2 sig figs? (To repeat what gneill already pointed out.)
You have:
E-field due to sigma1=13.35e-6 C/m2
E-field due to sigma2=-8.65e-6 C/m2​
But, if they're both pointing left (as vectors), then they should both be negative !
E1 + E2 = -13.35×10-6 + -8.65×10-6 = ____ ?
yes that's the way I ended up doing it -13.35e-6+-8.65e-6
That's stange, I don't see that result anywhere in this thread.
