Finding the flow of a vector field
docnet
Find the flow of the vector field V(x, y) = (y, x)
V(x, y) = (y, x)
Homework problem: Find the flow F_t((x0, y0)) = (xt, yt) of the vector fields a) x X + y Y, b) X + x^2 Y, c) y X + x Y, then verify F_s o F_t = F_(s+t).
In part c, plotting the vector field shows the vector field is symmetric in x and y in the sets {x=y}.
Plot of a vector field on a grid from -10 to 10 on both axes, with red arrows that point toward the lower-left in the upper-left region, toward the upper-right in the upper-right region, and mirror this pattern through the origin in the lower half.
in {x=y}, the variables can be interchanged and the solution becomes
x = x°e^t
y = y°e^tHowever, these solutions do not work for anywhere except {x=y} and don't satisfy dx/dt = y and dy/dt = x
yX+xY corresponds to the system of ODES
dx/dt = y
dy/dt = xWe eliminate dt from the above system to obtain the following solution to the system of ODES
(x^2)/2 - (y^2)/2=c
However I believe we cannot parametrize this equation to obtain the flow of the vector field.
What I did find from algebraic manipulations is
x = (x°e^t)/2 + (y°e^t)/2 + x°/2 - y°/2
y = (x°e^t)/2 + (y°e^t)/2 - x°/2 + y°/2
which satisfies the values t = 0, x = x°, y= y°
We tried to find the flow by t and s and the calculator tells us this is the wrong answer. Any ideas at all would be appreciated. thank you.
If ##dx/dt=y## and ##dy/dt=x##, then you can substitute one equation into the other to find ##y=dx/dt=d^2y/dt^2## and similarly ##x=dx^2/dt^2.## Then solve and use initial conditions.
Thank you for the advice. We tried this method and obtained the following solutions.
x=x°e^t + c te^t
y=y°e^t + c te^t
We found that the constant c can be set to x°-y° or y°-x° to satisfy dx/dt=y or dy/dt=x. Yet, neither choice satisfies the two initial conditions at the same time.
This is a strange situation because the equations say c = x°-y° and c = y°-x°.
x=x°e^t + c te^t
y=y°e^t + c te^t
The solution of [itex]\ddot x = x[/itex] is [tex] x = A \cosh t + B \sinh t[/tex] and its derivative is [tex] \dot x = A\sinh t + B \cosh t.[/tex] Since [itex]\cosh(0) = 1[/itex] and [itex]\sinh(0) = 0[/itex] it is easy to impose the initial conditions.
There are two dependent variables Therefore there are two constants of integration. They don't have to be equal.
dx/dt = y
dy/dt = x
(x^2)/2 - (y^2)/2=c
You might as well absorb the factor of 1/2 into the constant ##c## so ##x^2-y^2=c##. Depending on the sign of ##c##, you can parameterize using the hyperbolic functions. If ##c>0##, you can write
\begin{align*}
x &= \sqrt{c} \cosh (t-t_0) \\
y &= \sqrt{c} \sinh (t-t_0)
\end{align*} If ##c<0##, you'd need to swap ##\cosh## and ##\sinh## and stick a minus sign in the square root.
Note this is the same solution as the one @pasmith gives in post #4.
You seem to be losing solutions along the way as there should be ##e^{-t}## terms as well. I'm guessing when you took a square root somewhere, you neglected the negative solution.
Theorem 1 statement: characteristic equation (2) has distinct real roots (-b ± √Δ)/(2a) with Δ = b² − 4ac > 0, then the general solution to (1) is y = e^(−bx/2a)(c₁ cosh(√Δ/(2a) x) + c₂ sinh(√Δ/(2a) x)), and every pair (c₁, c₂) yields a distinct solution.
Thank you Pasmith and vela, you are right, this method solves the problem!
using the hyperbolic solution to second order odes, I found the solution
x= x cosh t + y sinh t
y= x sinh t + y cosh t
here is a graph of the flow when x = -1 and y = -2 parametrized by t.
Parametric curve plot input in Desmos-style calculator: (-cosh t - 2 sinh t, -sinh t - 2 cosh t) with t ranging from -5 to 3.
Graph of a green curve against x and y axes with grid lines, peaking near (0, -2) and falling off on both sides, passing through about (-10, -10) and (10, -10).
vela, you are right, there are e^-t terms that I missed as well. I was tired after trying for many hours to solve this problem.
