Finding the force of kinetic friction without a coefficient
8 replies · 18K views
Her0
In a lab assignment we created a Fletcher's trolley system and were asked to calculate the normal force, the force of friction, and then create a graph of both to find the coefficient of kinetic friction.
So far, the variables I have are:
Hanging mass: 0.100 kg
Sliding mass: 0.1553 kg
Distance traveled by the sliding mass: 0.398 m
Time taken for the sliding mass to reach the ground: 0.89 s
Acceleration of the system: 1.01 m/s^2
Normal force: 1.52 N
Force of friction : Unknown
The acceleration of the system was found using the equation a=(2(d-vit))/t^2 which i simplified to a=2d/t^2 since vi was 0 m/s.
The normal force of the sliding object was found using Fn = mg
The force of friction would be calculated using Ffk = Fn*μk but I don't have μk.
As stated above, I tried using Ffk = Fn*μk but i didn't have all the variables.
on Phys.org
Did you draw free body diagrams for each of the 2 blocks and then write equations to relate sum of the forces to acceleration for each block?
Okay so I tried doing that and essentially what I got was that Ffk = Mg - ma where Mg is the force of the hanging object and ma is the force of both masses of the system multiplied by the system's acceleration because Fnet = Fapp -Ffk.
I'm not used to working with systems. I would normally write separate equations for each block and then solve the two equations with the two unknowns. But I think your equation below makes sense.
Her0 said:
Ffk = Mg - ma
So I think you have everything you need to solve that equation, provided you rewrite Ffk in terms of the normal force. You know the masses and acceleration.
I did not know what Fapp was.
Edit: P.S. Welcome to Physics Forums.
Fapp was a formula for applied force which I used to derive my new formula for Ffk. Other than that, I now have everything I need to calculate the force of friction. Thank you!
Let me know what you get for a final answer. I always like to check my work.
So I subbed in the values resulting in the equation becoming Ffk = (0.100 kg(9.81m/s^2))-((0.100kg+0.1553kg)(1.01m/s)) which resulted in the answer being 0.723 N rounded to three significant digits.
Okay, that looks right. For some reason, I was thinking that the goal of the problem was to find the coefficient of friction. And as I now re-read the problem statement, finding the coefficient of friction is indeed the final question. I just don't know why you would need to create a graph to do that.
It's just a procedure my professor told us to use even though we could find the coefficient using μk = Ffk/Fn after Ffk was determined. Either way, thanks again for the help.
