Finding the force to break static friction
The problem involves determining the force required to overcome static friction for a stack of doughnuts being pushed by two individuals, as well as calculating the acceleration once the doughnuts are in motion. The subject area includes concepts of friction, forces, and motion in physics.
  • Participants discuss the application of the force equations and the relevant formulas for static and kinetic friction. There are attempts to calculate the normal force and the force of friction, with some questioning the assumptions made about motion and sliding.
The discussion is ongoing, with participants providing calculations and questioning the assumptions about whether the box is sliding or stationary. Some guidance has been offered regarding the need to consider both static and kinetic friction forces, but there is no explicit consensus on the correct approach yet.
Participants note that the problem involves two individuals pushing equally, and there is some confusion regarding the definitions of sliding versus static conditions. The values for gravitational acceleration and coefficients of friction are provided, but the application of these values is being debated.
nevererdofit
Samantha and Rebekah each push on a stack of doughnuts equally. If the coefficient of static friction is .28 and the box has a mass of 18kg, what force does each push individually to break static friction? Once it's moving, the coefficient of kinetic friction is .17, how much will the doughnuts be accelerated onto the floor?
mass of object = 18kg
coefficient of friction (static) = .28
coefficient of friction (kinetic) = .17[/B]
The only one I know that is obvious to use is f = ma, not sure how to apply it to this context[/B]
On the x and y plane, I know the force diagram reads normal force traveling up, force of gravity traveling down, Applied force traveling right, and force of friction traveling left.
Do you know the formula for static and kinetic friction?
I was never taught the formulas for each type of friction no
So after trying this is how I attempt it
(I assume gravity as 10m/s/s)
I know normal force = mg so fn = (18)(10) fn = 180N
then
f = (.28)x(180)
f = 50.4N
then I assume you divide the answer in two as it asks for the individual force, so
f = 25.2N
to find the acceleration you just use f = ma substituting your found force
25.2 = (18)a
a = 1.4m/s/s
am I correct?
Not quite. Is the box sliding or not?
they both push on the stack of doughnuts, so I believe it is sliding. Really though you are just trying to find the force that was needed to break the static force, or when it wasn't in motion. Then the second part of the question just wanted the acceleration of their push
Yes, so when you found the first answer did you assume the box was sliding or not?
yes I did assume the box was sliding as there was force being emitted on it
Well, you are contradicting yourself because you also said there was no motion. Sliding= motion.
then
f = (.28)x(180)
f = 50.4N
f = 25.2N
That looks correct.
25.2 = (18)a
a = 1.4m/s/s
am I correct?
A couple problems with this part. You've ignore kinetic friction force and only used one of the applied forces.
  • · Replies 42 ·
