Finding the Initial Velocity and Angle of a Cannon Ball Launched from a Cliff
The discussion revolves around calculating the initial velocity and angle of a cannonball launched horizontally from a 16m high cliff. The initial horizontal velocity is denoted as 'v', and the final velocity upon impact is given as '4v'. Participants explore kinematic equations to derive the vertical and horizontal components of motion, ultimately determining that the vertical component of the final velocity is 17.7 m/s. The relationship between the velocities is clarified using vector addition, leading to the calculation of the angle of impact. The conversation concludes with confirmation that the approach to finding the angle is correct.
safat
Classic cannon ball launched with an initial horizontal velocity from an elevated position.
Initial hvelocity: v
Final velocity (when hits the ground): 4v
High of the cliff: 16m
Find the initial velocity and the angle at which the ball strikes the ground.
R=vt+1/2*a*t2
finalv=v+a*t
First, I find the vertical/horizontal info
initial horizontal velocity:v initial vertical velocity:0
horizontal acc:0 vertical acc:-9.82
horizontal velocity at instant t:v vertical velocity at instant t:gt
horizontal displ: v*t vertical displ:16??
I find t=√2s/a using the vertical info, but then I get stuck..
any hint please?
Find the vertical component of the final velocity. (First in terms of v.)
Then you might want to use another kinematic formula to relate speed and distance for accelerated motion.
Yep
I got v=17.7ms-1
I am really tempted to do 17.7/4 => u=4.4ms-1, but I guess it's far too easy and sounds wrong.
I have also noticed that if I put v and h as vectors nose to tail, I have 4v as a resultant vector. I am kind of sure this is the way for finding the angle of impact.
safat said:
Yep
I got v=17.7ms-1
That's the vertical component of the final velocity in m/s, but that's not what the problem is calling 'v'. Express this speed in terms of 'v'.
Hint: Pythagoras
Ok, sorry for the poor quality of the sketch, but I want to be sure I understand this problem.
Am I right by doing so?
Thus I can find the angle between 4v and v, as the angle of impact.
Yes.
great.
thanks for your help!
