Finding the Maximum and Minimum Values
  • Thread starter Thread starter CloudTenshi
    Maximum Minimum
The discussion focuses on finding the maximum and minimum values of the function 3x + 3y + 2z on the sphere defined by x² + y² + z² = 1 using Lagrange multipliers. Participants confirm that using Lagrange multipliers is appropriate, but there are challenges in solving the resulting equations. The correct approach involves expressing x, y, and z in terms of the Lagrange multiplier, L, and substituting back into the constraint to find the values of x, y, and z. Ultimately, the maximum and minimum values are determined to be 11√(2/11) and -11√(2/11), respectively. The discussion highlights that it is possible to solve these problems without explicitly finding the multiplier.
CloudTenshi
Find the maximum and minimum values of 3x+3y+2z on the sphere x^2+y^2+z^2=1 .
Use of LaGrange Multipliers (maybe?)
I have no idea if LaGrange multipliers is the way to go or not, but I took the partial derivative for x, y and z
Partial x = 3
Partial y = 3
Partial z = 2
Using LaGrange Multipliers
I then got the following equations:
3=lambda2x
3=lambda2y
2=lambda2z
Lambda being the LaGrange Multiplier I believe.
I also have the equation of the sphere or x^2+y^2+z^2=1
However, from here I had no idea where to go next. I tried to solve out the LaGrange Formulas but couldn't get a coherent answer. Am I on the right track or do I need to just forget LaGrange?
You are on the correct track. Where specifically are you running into a problem?
I am having trouble solving out my lagrange multipliers. Like if I solve it out, I think I get lambda being 3/2 leaving x and y as 1 and z as 2/3.
I don't really see how you get that. Solving for x, y, and z should give you x = 3L/2, y = 3L/2, z = L. Then you can use these values in the restraint (the equation of the sphere) to solve for L.
I had always thought that you were supposed to just be able to look at the equations and find lambda or what not because that's what the teacher had done, but this way actually makes sense.
So I solved out the L in the equation of the sphere and got sqrt(4/22)
Plugging it back into my equations I solved for x, y and z and got:
x= 3sqrt(22)/4
y= 3sqrt(22)/4
z= sqrt(4/22)
from here I just plug in these values into the original function to find the maximum and minimum values right?
Well, substituting back into the constraint, I get L^2=4/22=2/11. Doesn't that have more than one solution? You should probably expect to get two, since there ought to be a max and a min. There seems to be some flipping of L and 1/L going on here, which is ok, but it would be nice to stick with one. Can you show your complete solution, CloudTenshi?
I just realized I made a few typos on the last one, but after solving for the x, y, and z using the value I got for L which was the sqrt(11/2) and -sqrt(11/2). From this, I was able to get the x, y, and z values which are:
x=3/(2L) = plus or minus (3/2)(sqrt(2/11))
y=3/(2L) = plus or minus (3/2)(sqrt(2/11))
z=1/L = plus or minus (sqrt(2/11))
I then plugged the the values back into the original function to find the max, which is when everything is positive, and min which is when everything is negative.
I think I should have the right answer.
The max is 11sqrt(2/11)
and min is -11sqrt(2/11)
Yeah, I think you got it.
Thanks. I think it all became clear for me when I found out that I was supposed to solve for L and then for the x,y,z coordinates.
By the way, it is often possible to solve max-min problems, using Lagrange multipliers, without ever finding the multiplier itself! For example, you have
3=\lambda 2x, 3=\lambda 2y, and 2=\lambda 2z.
Dividing the second equation by the first eliminates \lambda giving 1= y/x and dividing the third equation by the first gives 2/3= z/x so that y= x and z= (2/3)x. Put those into the equation of the sphere to solve for x, then find y and z.
  • · Replies 18 ·
