Finding the median of a distribution
The discussion revolves around finding the median of a transformed random variable, specifically the distribution of e^X where X follows a Uniform (0,1) distribution. Participants are exploring how the properties of the uniform distribution influence the median of the transformed variable.
  • Participants discuss the need to find when the cumulative distribution function (CDF) equals 0.5 to determine the median. There is uncertainty about how to correctly apply the transformation from X to e^X and how the uniform distribution affects this process.
Several participants have attempted to derive the median but express confusion regarding the relationship between the uniform distribution of X and the resulting distribution of e^X. Some have proposed that the median could be e^0.5, while others question the validity of this assumption and seek clarification on the steps involved in finding the median.
Participants note potential misunderstandings regarding the transformation of variables and the implications of the uniform distribution on the median calculation. There is also mention of notation that may lead to confusion, particularly in relating the variables X and Y.
doctordiddy
Suppose X has the Uniform (0,1) distribution. Find the median of the distribution of e^X correct to 2 decimals.
F(X) = 0.5
F(X) = ∫f(x)
I am not entirely sure what to do here, I know to find the median you need to find when F(X) = 0.5. I assumed that e^X was just the cdf f(x) = e^X which makes F(x) still e^X.
So then I used e^(X) = 0.5 which gives X = ln(0.5).
However this is not correct. I am a bit confused about the first part of the question, how X being a uniform distribution would affect it.
Any help would be appreciated
Thanks
F(X) = 0.5
F(X) = ∫f(x)
If you think about it a bit, this can't be right, since X would have to be a negative number. If X ranges from 0 to 1, then e^X will range from ? to ?
Thanks
I found the answer to be e^0.5, but I am not sure exactly why. Do we find the median of the uniform distribution of X (0.5) and then plug that into e^(X)? Or do I need to find the median of the distribution between 1 and e? If it's the latter, how do we know that the median is simply e^(0.5)? Are we able to say this because X is a uniform distribution?
If ##Y = e^X##, the cumulative distribution of ##Y## is ##F(y) = P(Y \leq y) = P(e^X \leq y)##. For ##X \sim U(0,1)##, what does this give you for ##F(y)##? What is the solution of ##F(y) = 1/2##? That would give you the median.
I am unsure of how to continue after
For ##X \sim U(0,1)##, what does this give you for ##F(y)##? Am I supposed to see that X = ln(y) or am I supposed to see that Y ~ U(1,e)? Or am I missing something altogether?
Some risk of confusion in the notation. That X = ln(Y) is self evident, so I'm assuming your question is why x' = ln(y'), x' and y' representing the medians of the respective distributions.
As Ray wrote, for any x, the event Y < ex is the same event as X < x. Therefore FY(ex) = FX(x). Setting x=x' we get FY(ex') = 0.5.
That is certainly not the case.
  • · Replies 23 ·
