Finding the minimum value that an expression can take.
The discussion focuses on finding the minimum non-negative value of the expression k + k^-1, which is established to be at least 2 using the inequality (k-1)² ≥ 0. This inequality is expanded to k² - 2k + 1 ≥ 0, then manipulated by dividing through by k (assuming k > 0) to derive k + 1/k ≥ 2. Participants express confusion about how to derive useful inequalities for similar problems and whether there is a general method for creating them. The conversation concludes with an acknowledgment of the clarity gained regarding the application of quadratic inequalities in this context.
HuaYongLi
I've recently come across a http://technologyinterface.nmsu.edu/Spring08/" for why power is maximised in a component when its resistance R_L equals the internal resistance R.
But in part (5) of method 1, we need to find the minimum non-negative value that the expression k+k^-^1 can take. For this they use the inequality (k-1)^2 \geq 0 and then expand it to k^2-2k+1 \geq 0 which is then in turn divided by k and rearranged to get k+k^-^1 \geq 2
The problem I have grasping is the part where they come up with the inequality to solve this problem. This is a step I have never come across, and I was wondering if this method had a name.
Thanks
Mathematics news on Phys.org
Are you asking a physics question, i.e. where did the question about k + 1/k come from?
The math proof ( ≥ 2) is simple enough (assuming k > 0).
Maths
Use that the arithmetic mean is larger than the geometric mean.
HuaYongLi said:
Maths
(k-1)2 ≥ 0
expand quadratic
k2 -2k + 1 ≥ 0
divide through by k (need k > 0)
k - 2 + 1/k ≥ 0
add 2 to both sides
k + 1/k ≥ 2
Thanks
If you're asking where the initial inequality comes from, any real number squared is always greater than or equal to zero. That's the reason for saying (k-1)^2 \geq 0.
Yes, but is this a matter of just thinking of a quadratic inequality that when manipulated will give desired terms k and 1/k?
The last two replies seem to make it as clear as possible. It is a trivial derivation. What don't you get?
I know the inequality can be used to find the minimum and how to manipulate it. My problem is how to actually come up with an inequality that will be of use in the first place, say I have (k-2)^{2}\geq0 - it's not going to be useful for our purposes when manipulated. Well, obviously one can see that the first (k-1) inequality will be the one to choose. I want to know whether this can be generalised for any quadratic inequality where you want to find not just x is more than/less than a; but x and another non constant term.
It just seems to me that some steps are being skipped in the paper.
You can generalize with (k-n)2 ≥ 0 to get k + n2/k ≥ 2n.
Where it might be used I don't know.
Thank you, I've gotten what I need to know.
