Finding the moment of inertia of a skeletal frame
The discussion revolves around calculating the moment of inertia for a skeletal frame, specifically with respect to a vertical axis. The original poster describes a personal project involving a frame with rods of varying lengths and orientations, seeking guidance on how to approach the problem given the complexity of the setup.
  • Participants discuss the use of the parallel axis theorem and the original poster's attempts to sum the moments of inertia for different rods. Questions arise regarding the appropriate axis of rotation and whether to consider the center of mass or a displaced axis for calculations.
There is an ongoing exploration of different methods to calculate the moment of inertia, with some participants providing guidance on using established equations. The original poster has shared calculations and is seeking validation on their approach, while others are questioning the assumptions made regarding the axis of rotation and the application of formulas.
Participants note that the frame is mounted on a near frictionless spin table, which influences the dynamics of the system. There is also mention of specific constraints regarding the mass and lengths of the rods involved in the calculations.
lzh
This isn't a homework problem but rather a problem I need to solve for a personal project of mine. Basically I need to find the moment of inertia of the following:
http://img860.imageshack.us/img860/3952/roboframe.jpg
Uploaded with ImageShack.us
The rotation is with respect to the top of the square frame
I=[tex]\Sigma[/tex]mr^2
Iend=mL^2/3
Icenter=mL^2/12
What this problem comprises of essentially is just a bunch of rods with differing axis of rotation. I would simply need to sum the total. Now I've been only spoon fed the equations above for rotation on the end of a rod or center of a rod, never the equation for a rod with an axis of rotation off the rod. I would need to use the Iend equation for the rods in the middle, but the overall frame of this structure would need another equation. Could someone guide me to finding that equation?
thanks
hi lzh! :smile:
(have a sigma: ∑ and try using the X2 icon just above the Reply box :wink:)
use the parallel axis theorem …
moment of inertia about any point = moment of inertia about the centre of mass + md2, where m is mass and d is distance from the centre of mass :wink:
(try it first for the end of a rod, to check it really works! :biggrin:)
hi,
thanks for the help!
if I were to have two motors spinning on this frame, one on the "top" of the frame, and one on the bottom. Should I be solving for the moment of inertia with respect to the center of mass, or should it be displaced?
sorry for the double post. But here are my calculations:
assume every rod has mass m. length of the orange/black rod is l and length of blue rod is r.
I=12rods*I(orange/black)+8rods*I(blue)
I=12*m(l^2/12+l^2/2)+8*(mr^2/3)
does this make sense?
hi lzh! :smile:
i don't understand …
what are the motors doing? :confused:
are they, for example, making the frame spin about a fixed vertical axis?
you should choose the centre of mass, or any point on the axis of rotation
nooo :redface:
about what axis are you measuring the moment of inertia ?
basically those two motors are attached to the frame, and the spinning end of the motor freely rotates. The frame is on a near frictionless spin table, so anything rotation from the motor will cause an opposite spin on the table. And so yea its making the frame spin about a fixed vertical axis.
I'm measuring the moment of inertial with respect to the vertical axis in the center of the frame. So i simply used the rod equation ml^2/12 and displaced it by how far it is from the center axis. Then I summed the total of all the rods that are not diagonal to the axis. For the blue rods, I usedI=ml^2/3.
Was this not right?
for the blue rods, the axis goes though the centre of the rod, so use ml2/12 with nothing added, but with a longer l of course
for the other horizontal rods, your method is correct
for the vertical rods, starting with ml2/12 is wrong, you need instead the moment of inertia about the vertical axis through the centre of mass, which is … ? :smile:
  • · Replies 16 ·
  • · Replies 21 ·
10K
