Finding the net work done on an object
To find the net work done on an object with a mass of 42.5 kg and a 325 N force acting at a 27° angle, the calculations involve determining the work done by the applied force and friction. The work done by the pulling force is calculated as 92665 J, while the friction force of 87 N results in -27840 J of work. The net work is then found by summing these values, resulting in 64825 J. However, there is a discrepancy with a provided answer of 7.46*10^4 J, prompting a discussion about potential errors in the calculations. The conversation highlights the importance of careful calculation in physics problems.
Shyamalan
A 325 N force acts on an object with a mass of 42.5 kg at an angle of 27° , pulling the object along a flat surface. The coefficient of friction is 0.21 and the object's displacement is 320m.
Calculate the net work done on the object.
W=Fdcos(θ) Fg=mg Ffr=μFN
Ok, so I know FN in this case is equal to Fg, and the work done by the two is 0 J, because they perpendicular to the displacement. The work done by the pulling force is 325*320*cos(27) which is 92665 J. The friction force is 0.21*42.5*9.8 which is 87 N. The work done by the friction force is 87*320*cos(180) which is -27840 J. The net work is the sum of these two values, 92665+(-27840) which is 64825 J.
Now, the answer given is 7.46*10^4 J, which is one digit off of my answer. Am I doing something wrong or is there a typo in the answer I was given?
Welcome to PF!
Hi Shyamalan! Welcome to PF! :smile:
Shyamalan said:
Ok, so I know FN in this case is equal to Fg …
Noooo :rolleyes:
Pfffft... Whoopsy, I got it now. XP
  • · Replies 58 ·
