Finding the point of intersection between two curves. (Vectors)
The problem involves finding the point of intersection between two parametric curves defined by r1(t) = (t, 4-t, 63+t^2) and r2(s) = (9-s, s-5, s^2). Additionally, the task includes determining the angle of intersection between the curves.
  • Participants discuss the substitution of parameters to find the intersection point and the use of derivatives to determine tangent vectors at that point. Questions arise about the correct method to compute the angle of intersection and the interpretation of the results.
Some participants have provided guidance on finding tangent vectors and using the dot product to calculate the angle between them. There is ongoing exploration of the intersection point and the relationship between the parameters t and s.
Participants express uncertainty about the steps following the substitution into the parametric equations and the interpretation of the results. There is mention of potential confusion regarding the values obtained for the intersection point and angle.
Jaqsan
At what point do the curves r1(t) = (t, 4-t, 63+t^2) and r2(s)= (9-s, s-5, s^2) intersect?
Answer in the form: (x,y,z) = ____
Find the angle of intersection theta to the nearest degree.
i: t=9-s
j: 4-t=s-5
k: 63+t^2=s^2
i/j: t-9s
k: 63+(9-s)^2=s^2
"Solving for "s""
s=8
t=1
I know not what to do from here. :-(
Welcome to PF Jaqsan,
i: t=9-s
j: 4-t=s-5
k: 63+t^2=s^2
i/j: t-9s
k: 63+(9-s)^2=s^2
"Solving for "s""
s=8
t=1
It sounds like you want to find the "direction" of each curve at the point of intersection. Can you think of a vector that describes this, and how to compute that vector given r(t)?
I don't understand. The question asks for the point of intersection of the two curves. Do I find the derivative, dot product? Just point me in the right direction please.
Jaqsan said:
s=8
t=1
What is the vector r1 when t=1?
You already found the intersection point correctly. So the two tangent vectors are r1'(1) and r2'(8). What are they? Then the angle between two vectors a and b is a.b/(|a||b|). Use that.
Okay, so I got
r1'(1) = <1,-1,2>
r2'(8)= <-1,1,16>
So do I dot them to get them in one (x,y,z) form?
Jaqsan said:
Okay, so I got
r1' = <1,-1,2>
r2' = <-1,1,16>
Ummm, to answer the (x,y,z)=___ you just substitute. To answer the angle question you want to form a dot product.
I thought I already did the substitution. r1' = <1,-1,2> r2' = <-1,1,16> What I'm trying is it looks like there are two numbers for each value <x,y,z>
You substituted correctly into the derivatives. That's fine. When they are asking for the intersection point (x,y,z) you should substitute t=1 into r1(t) or s=8 into r2(s). That's what you calculated for the intersection point, yes? They had better both be the same.
Thanks. I figured it out. I was just being retarded. My answers are (1,3,64) and 40degrees
Jaqsan said:
Thanks. I figured it out. I was just being retarded. My answers are (1,3,36) and 40degrees
I think you mean (1,3,64), right?
My bad. Exhibiting my retardness once again. (1,3,64) and 40 degrees.
23K
