Finding the problem with a torque equation
  • Thread starter Alt+F4
    Exam Final
112 replies · 14K views · last reply
Alt+F4 said:
http://online.physics.uiuc.edu/cgi/courses/shell/phys101/spring06/prep2a.pl?practice/exam1/sp04 Question 11, why are they equal there is a vertical component for the second box which is mgsin 45 while for the first it is 0
Well, how do you find the vertical component?
~H
Stupid question, but i get soo confused when do i know the say acceleration will be negative in this equation like Friction - Tension = ma
Is there key words in the problem or what cause sometimes it is positive some times it is negative
~H
well vertical component is just if there is an angle then you have one
What would happen if there was an unbalanced force acting upwards?
HINT: What other force is acting upwards in BOTH cases.
~H
~H
Normal Force is acting upward
Yep, but what would happen if there was a net force acting upwards on a block?
~H
~H
then it would equal
Alt+F4 said:
then it would equal
What? Using Newton's second law, what would happen if there was a net upwards force?
~H
http://online.physics.uiuc.edu/cgi/courses/shell/phys101/spring06/prep2a.pl?practice/exam1/fa03
Question 8, why couldn't it not have been done like this 1.4/9.8 = .14
The co-efficent of friction is given by;
[tex]\mu = \frac{F}{mg}[/tex]
Where F is the maximum frictional force. You have to take into account the force that the tractor is pulling.
~H
~H
um so what i did was add all the weights multiply by 9.8 is that even right and then i divided by the tractor weight or am i missing something
No, I'm afraid it isn't right. The reaction force (mg) is due to the tractor's weight only. The F is the force required to accelerate the total mass at 1.4 m.s-2. Do you follow?
~H
~H
o yes, thanks
http://online.physics.uiuc.edu/cgi/courses/shell/phys101/spring06/prep2a.pl?practice/exam1/sp03
Question 23
I did centripetal Acceleration * weight
50 * .5 = 25 is this the right way?
Question 23
That's fine. (I assume you meant to write mass, not weight.)
http://online.physics.uiuc.edu/cgi/courses/shell/phys101/spring06/prep2a.pl?practice/exam2/fa05 Last question, i still don't get how to set it up incase he asks the same question and wants the resultant velocity
so
(1.5*10^5)(8) = (-4*1.5*10^5) + (1.5*10^6*X)
Is this the setup
so
Is this the setup
That's how I'd do it.
http://online.physics.uiuc.edu/cgi/courses/shell/phys101/spring06/prep2a.pl?practice/exam2/sp05
Question 6
So what i was thinkin is to do it this way
so work done by friction = W = *.43*9.8*12 = 50.568
Total Kinetic Energy = MGH + .5 MV^2 = (9.8)(9) + .5 (20^2) = 288.2
288.2-50.568 = 237.632
Edit: well it works if i don't take in effect the PE of the hill but why not?
Question 6
Why should the 9 m hill matter? Since there's no friction, the KE is the same before and after climbing that hill.
http://online.physics.uiuc.edu/cgi/c...ice/exam1/sp99 Question 25
here was my plan divide the thing into 2 so 55 M on left, 55 M on right
do Tan 35 = X / 55
The Height = 38.5114
Okay then i decided to just do
38.5114 = .5 * 9.8 * T^2
T = 2.80
Okay another way
(2)(9.8)* 38.5114 = V^2
V = 27.47405
so what i did was divide that be Cos 35 and got 33.53 why am i off?
http://online.physics.uiuc.edu/cgi/courses/shell/phys101/spring06/prep2a.pl?practice/exam2/fa04
Question 16
So i know that Change in kinetic = Uk g * D
So what i did was (22)(9.8) + (9)(9.8) = X * 9.8 *53
wat am i doing wrong
Question 16
Your problem is this equation. Why have you added additional GPE [+ (9)(9.8)]?
~H
Question 19
So Wnet = 8.6483
Wnet - Force of friction - Force of gravity
I did get the above questions right so i know the numbers are right
8.6483 = .5 mV^2
V = 2.9773
The 3 is the ending velocity
(-2)(2.9773) - (2)(3) = -11.9546 ( Total Momemtum)
Fave T = P
X (.06) = (11.9546)
X = 200
Is this how it is done
WHen it says you Double The Frequency does it Actually mean Multiply it by 2 or does it mean Half it?
In what context? What is the full question?
~H
Question 19
So Wnet = 8.6483
8.6483 = .5 mV^2
V = 2.9773
Fave T = P
X (.06) = (11.9546)
X = 200
Why have you gone through the trouble of calculating the velocity just before impact when it is given in the question? :wink: But yes you working is correct. The change in momentum will be -6m and you were correct to use the impulse relationship.
~H
Suppose the mass of the string in the above problem is M0. What is the mass of a new string (in terms of M0 ), if the fundamental frequency of the string is doubled compared to the previous value, but the length and tension in the string are the same as before?
Now does this Mean Frequncy * 2 or frequency / 2
do Tan 35 = X / 55
T = 2.80
Okay another way
V = 27.47405
let me just quote this so it doesn't get lost
It means the fundemetal fequency is twice what is was before. I.e. If intially the fundamental frequency was 50Hz, the new fundamental frequency would be 100Hz.
~H
I answered this above in post #86 :smile:
~H
