Finding the shortwavelength limit of the white spectrum
  • Thread starter Thread starter Noone1982
    Limit Spectrum
The discussion focuses on determining the short wavelength limit of the white spectrum derived from Bragg scattering of X-rays produced by a copper anode on a NaCl crystal. The user conducted two trials with X-ray energies of 20 KeV and 30 KeV, aiming to convert their data from counts vs. degrees to counts vs. wavelength. The key equation involved is hf = h(c/λ) = E = 20 KeV. The user initially attempted to use the equation λ = 2d*sin(theta) for conversion but encountered significant errors in calculating Planck's constant.
  • Understanding of Bragg's Law and X-ray diffraction
  • Familiarity with the concept of wavelength and energy relationship in quantum mechanics
  • Knowledge of X-ray production and detection techniques
  • Basic proficiency in trigonometric functions and their application in physics
  • Learn how to convert angular data to wavelength using Bragg's Law
  • Study the principles of X-ray diffraction and its applications in material science
  • Explore methods for accurately measuring Planck's constant through experimental data
  • Investigate the effects of varying X-ray energies on diffraction patterns
Physics students, researchers in material science, and anyone involved in experimental physics seeking to understand X-ray diffraction and its implications for measuring fundamental constants.
Noone1982
I am trying to find the short wavelength limit ( and consequently plankcs constant) of the white or bremstrahlung spectrum. The data came from the bragg scattering of x-rays produced from a copper anode scattered of a NaCl crystal. The graph is counts vs degrees. The spectrum is from 11-30º on a 2-theta scale. There were two trials for the white spectrum, one of 20 KeV x-rays and the other of 30 Kev x-rays. The shortwavelength limit is defined as the intersection of the x-axis.
One of the main equations is,
hf\; =\; h\left( \frac{c}{\lambda } \right)\; =\; \mbox{E}\; =\; 20\; KeV
The problem is that my data is in counts vs degrees, not counts vs wavelength. I need my x-axis to be in wavelength, not the recorded degrees. I am not sure how to convert it.
I am a bit clueless on this one. I tried using 2d*sin(theta) = n*lambda to convert the degree axis into a wavelength axis, I knew it would be wrong iand sure enough, I got a Planck's constant of five magnitudes off.
Surely someone must know! Or is it too hard? :(
If you have a rotating crystal and plot signal vs. rotation angle, then by knowing theta (incident angle relative to the crystal surface) and the crystal 2d spacing you can calculate signal vs. lamda from lamda = 2d*sin(theta). Perhaps you referenced the angle to the crystal surface normal instead?
D'oh! Sorry for taking your time, my initial approach was correct but I must have done some silly calculator error.
  • · Replies 16 ·
  • · Replies 37 ·
12K
9K
