Finding The Tension force with different angles
6 replies · 6K views · last reply
Ashleyz
I have done all the physics for this problem which I'll detail below. I am only having trouble in doing the simple math to single out the t1 or t2.
A mass is hanging from a ceiling. It is supported by two strings which both are attached above to the ceiling. String 1 is at an angle of 30. String 2 is at an angle of 65. While the
mass is 20 lb. ( in the center)
Ma = 0 in both the x and y directions.
left T (T1) =30 degrees
right T (T2) = 65 degrees.
ok, here are my equations that I get to:
X: T2cos(65) - T1cos(30) = 0
Y: T2sin(65) + T1sin(30) = 0
now I just need to solve for, say, T1 in the x dierection and use that new eq. to
pluge into Y. Right?
The 20 pounds is the value of the weight of the hanging mass; it is not the mass. In your last equation in the y direction, you are missing a force.
right. I am missing -w. Sorry about the mistake.
Now what of the T that I need to solve for. I have Solved for the T in my
x and y equation and get bad nasty answers.
Do you mean this:
I'll take the x eq. and solve for t1.
I get T1 = T2cos(65) / cos (30)
now I can take this eq. for T1 and plug it in for T1 in the y eq?
It will be a lot easier if you rewrite your first equation as T1= T2(.423)/.866 = 0.49T2. Rewrite the 2nd equation in the same manner, then do the substitution.
I see.
T1 = T2(.49)
T2 = 21.74lb + T1(.54) I divided .92 into lbs., think you can do that.
now ill put T2 in the T1 eq. Right?
