Finding time for a horizontal projectile from an 78.4 m cliff
  • Thread starter Thread starter feod2003
    Major Time
9 replies · 5K views
feod2003
How would you get time for this:
5. A stone is thrown horizontally at 8.0 m/s from a cliff 78.4 m high. How far from the base of the cliff does the stone strike the ground? (Use GUESS Method)
G: vi = 8.0 m/s
g = 9.8 m/s2
dy = 78.4 m
U: dx
E: d = vi*t +1/2 a*t^2
S: dx = 32 m
vi =initial velocity
^2= squared
*= times
The motion in the y-direction and in the x-direction are independent, right?
So first you'll want to use equation "E" to calculate the time is takes the rock to fall the 78.4m. Then, use the time you found in a similar equation, but for the x distance (of course is no acceleration term in equation "E")
I don't know what the GUESS method is, but the first thing I would do is ignore that any type of horizontal motion exists. I would imagine the stone simply being dropped off the cliff. With the knowledge of the height of the cliff and the fact that it is dropped (vi = 0) you can calculate the amount of time that the stone is in the air. Now I remind myself of this horizontal velocity that the rock was given. To calculate the horizontal distance I just use d = vi*t +1/2 a*t^2. There is no acceleration in the x direction so it is simply D = ViT. You know the initial velocity and you calculated the time.
...But how would i get the time, i don't know how to get it?
G: vi = 8.0 m/s
g = 9.8 m/s2
dy = 78.4 m
U: dx
S: dx = 32 m
^2= squared
*= times
I don't know what the GUESS method is. However, you should note that v_i is 8m/s in the x direction. V_xi =8. There is no initial component of v in the y direction. V_yi = 0. In the x direction, there is no acceleration, so v_x stays constant throughout the trip, therfore, x =v_x(t), this is the horizontal distance traveled. To solve for t, use your the "E" equation in the y direction, where d =78.4 , v_i = 0, and a =9.8. Then solve for x, I guess.
wow thanks that helped a bit, thanks guys
I got another one.
7.A dart player, standing 3.2 m away from the dartboard, throws a dart horizontally at a speed of 12.4 m/s. How far from the bull’s eye (where the player aimed) did the dart strike? (Use GUESS Method)
G: g = 9.8 m/s2
dx = 3.2 m
vi = 12.4 m/s
U: dy
E: d = vit +1/2at2
S: dy = 0.32 m (give a direction)
need more help fast.?
I think people on these boards are more familiar with the ViVfdat method (same sort of thing...)
again same sort of concept as ur last problem...no initial y velocity...no x acceleration...then just set up a system with the values...knowing that acceleration in y direction is g and then solve...its similar to the last one u did if you got it...just having a different unknown this time...meanign a different equation...
Vix 12.4
Vfx 12.4
Dx 3.2
ax 0
t = t
Viy = 0
Vfy = ?
dy = x
ax = -g
t = t
whats the only common variable between the two sets?
Vix 12.4
Vfx 12.4
Dx 3.2
ax 0
t = t
Viy = 0
Vfy = ?
dy = x
ax = -g
t = t
umm... is that guna be t?
