Finding time using a given torque, etc.
  • Thread starter Thread starter aligass2004
    Time Torque
The discussion centers on calculating the time required for a flywheel to reach a specific angular speed using given torque and mass parameters. A flywheel with a diameter of 1.2m and mass of 250kg is spun by a motor applying a constant torque of 40Nm. Participants clarify the need to calculate the moment of inertia correctly, noting that for a disk, the formula is I = 0.5 * M * R^2. The correct angular acceleration is derived from torque and moment of inertia, leading to a recalculated time of approximately 1406 seconds after converting angular velocity from rpm to radians per second. The conversation emphasizes the importance of unit consistency in physics calculations.
aligass2004
Flywheels are large, massive wheels used to store energy. They can be spun up slowly, then the wheel's energy can be released quickly to accomplish a task that demands high power. An industrial flywheel has a 1.2m diameter and a mass of 250kg. A motor spins up the flywheel with a constant torque of 40Nm. How long does it take the flywheel to reach top angular speed of 1250rpm?
Wf = Wi + alpha(delta t)
I tried using the above equation except I substituted delta W/delta t for alpha. I got 2815.315s, but that seems awfully high, and it wasn't right.
I don't see how you would have got that to work. Did you use the information about torque? Do you know how to find the moment of inertia of a disk? You can find the angular acceleration using those two quantities. Once you've done that, use the equation under "relevant equations" to find the time.
I = m(r^2) = 250(.6^2) = 90. I did that and I got the exact same answer.
I'm still unsure about this problem.
Remember that torque = I * alpha. You found I, you were given the torque in the question. So you can get alpha.
Also, a flywheel is shaped like a disk, so for I you should use 0.5*M*R^2, not just M*R^2.
Ok, using the new I = 45, alpha = .889. So then substituting into Wf = Wi + alpha (delta time), delta time = 1406.074. Does that sound right?
Your angular velocity was expressed as 1250 rpm, (revolutions per minute). You need to change that to radians/second, so you units are consistent and correct. Do you know how to do that?
Why no I do not...I know how to change it to revolutions/second, but not radians/second
There are 2*pi radians per revolution.
Do I change revolutions/minute to revolutions/second then then do the 2pi radians?
Yes, you must do both.
Got it. Thanks!
15K
  • · Replies 23 ·
20K
