Finding v of a charged particle in a uniform magnetic field
The discussion revolves around a problem involving a proton moving in a uniform magnetic field within a rectangular region in the xy plane. The magnetic field has a strength of 0.06T and points in the -z direction. The proton enters with a velocity that has components defined by an angle of 24 degrees and exits 0.4m above its entry point, with the same vertical component of velocity but an opposite horizontal component.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the use of the Lorentz force equation and the integration of acceleration to find the velocity. Some suggest drawing the trajectory to locate the center of curvature for a simpler solution. Others question the assumptions made about the direction of the force and its influence on the velocity components.
Several participants have offered hints and alternative approaches, suggesting that determining the radius of curvature could simplify the problem. There is an ongoing exploration of the original poster's method, with questions raised about the integration process and the assumptions regarding force direction.
The original poster expresses frustration with their calculus skills and seeks to understand the flaws in their approach. There is a recognition that the force acts in a direction dependent on both velocity components, which complicates the integration process.
ThereIam
So there's a rectangular region in the xy plane subjected to a magnetic field B with strength 0.06T pointing in the -z. A proton moving in the xy plane enters the region with velocity v such that the velocity components are initially vx = v*cos(24), vy = v*sin(24). It leaves the rectangular region at a point 0.4m above (as in yf = yi + 0.4m, xf = xi) its entry with the same vy and opposite vx. What is v?
F = qv x B, qvB = mv^2/r
I figured I could just use F = qb x B to find the force in the y direction and then divided by the mass and integrated twice and set it equal to 0.4m, then solve for v, like
F/m = a = qvBcos(∅)/m
so=
x = 0.4 = ∫∫vqBcos(∅)/m d∅^2 + ∫vsin(θ)d∅ for ∅ = 24 to 154
then solve for v. The first integration is due to the B field and the second is just integrating the initial vy.
But I'm off by more than a couple orders of magnitude...
Any help would be appreciated! I suspect that my way isn't the easiest way, but if anyone could explain the flaw in my approach anyway that would be awesome.
Thanks for the help!
I think you can put away the heavy machinery if you draw the trajectory of the proton through the region and see if you can't locate the center of curvature (i.e., find the radius of curvature).
so=
What is the direction of the force wit respect to the velocity of the proton? Does not it influence the x component of velocity ?
If you want to get the change of position by integrating acceleration, and then the velocity, you have to integrate with respect to what?
ehild
Just one more hint: In this case it helps to write out the equations of motion for [itex]\vec{v}[/itex] explicitly in components and then decouple them, leading to a 2nd order ODE for one component.
vanhees71, that's what I thought I had done in my attempt above. It should say "y = 0.4" But anyway vcos(∅) = vy. F in the y direction I thought equals vqBcos(∅)*m. I thought by breaking them into those components I had decoupled them. Could you elaborate? Thanks!
Once again I offer the suggestion that if you can determine the radius of curvature of the proton's trajectory while it is within the region of the magnetic field then you can determine the velocity of the proton without a lot of mathematical strife.
You are essentially told that the entry angle and exit angle are mirrored; on exit the horizontal velocity is the negative of that on entry, and the vertical velocity is the same as on entry. Further, you are given the separation of the entry and exit. You also know (or should know!) that the trajectory of a charged particle while in a magnetic field perpendicular to the plane of the motion must be circular in nature. Determining the radius of that circle is equivalent to determining the velocity (see the OP's Relevant Equations).
So I offer up the following diagram for consideration:
Thank you very much for your responses gneill. I really do appreciate them, and I can see that they present a simpler approach to a solution.
I am still frustrated by my lack of understanding as to why my original approach didn't work. Something I'm trying to work on is my calculus skills (a great and unfortunate weakness of mine is in setting up problems appropriately using calculus) so even though your solution is both simpler and more elegant, I remain extremely curious where the problem in my original approach lay. Sorry that I did not express my gratitude for your thoughtful responses earlier.
You assumed that force acts only in the y direction. It is not true. The force is F=q[VxB], cross product of vectors V and B, and is perpendicular both to V and B. At the first instant, the force acts really in the y direction, and the particle accelerates and gains velocity in that direction. In the next instant, the direction of the velocity has both x and y component, and so is the acceleration. ax=(q/m)VyBz, and ay=-(q/m)VxBz.
You have to integrate the acceleration with respect time to get the velocity, and have to integrate velocity with respect time, to get displacement. You tried to integrate with respect theta. That was wrong.
ehild
  • · Replies 31 ·
