How Do You Find a Vector with a Specific Magnitude in the Opposite Direction?
The discussion centers on finding a vector in the opposite direction of <-4, 1, 2> with a magnitude of 3. The initial calculations correctly identify the unit vector as (4/sqrt(21), -1/sqrt(21), -2/sqrt(21)). To achieve the desired magnitude, the unit vector must be multiplied by 3, resulting in the final vector (12/sqrt(21), -3/sqrt(21), -6/sqrt(21)). The problem is classified as precalculus rather than calculus, highlighting the foundational nature of vector operations typically covered in earlier math courses.
  • Understanding of vector notation and operations
  • Knowledge of calculating vector magnitudes
  • Familiarity with unit vectors
  • Basic algebra for manipulating equations
  • Learn how to calculate vector magnitudes in 3D space
  • Study the properties and applications of unit vectors
  • Explore vector operations such as addition and scalar multiplication
  • Investigate the relationship between vectors and trigonometric functions in precalculus
Students in precalculus or calculus courses, educators teaching vector mathematics, and anyone seeking to strengthen their understanding of vector operations and magnitudes.
mmont012
Find a vector in the direction opposite to <-4,1,2>, that has a magnitude of 3.
I think that I did the first part of the problem correctly:
<-4,1,2>
magnitude= sqrt[ (-4)^2+1^2+2^2 ]
= sqrt(16+1+4)
= sqrt(21)
(-4/sqrt(21), 1/sqrt(21), 2/sqrt(21) )
to get the opposite direction, I would just change the signs
(4/sqrt(21), -1/sqrt(21), -2/sqrt(21) )
But I am confused at where to go from here. What does it mean "that has a magnitude of 3"? I may have approached this problem incorrectly. Any help would be great. Thank you for stopping by.
You have found a normal vector. The magnitude of a normal vector is ##1##.
Perhaps the answer is more trivial than it first appears, just think:
$$\sqrt{a^2 + b^2 + c^2} = 3$$
Select a vector ##<a, b, c>## such that the above is satisfied. Multiplying the original vector by ##-1## will help. In fact, one is the loneliest one, and the only one you'll ever need for this problem.
Likes mmont012
As Zondrina has pointed out, you have correctly determined a unit vector in the desired direction. Now, what do you need to multiply this unit vector by to produce a vector having the same direction, but with a magnitude of 3?
Chet
Likes mmont012
Ah, okay. I think that I was making this problem more difficult than it actual is. Thank you so much for the help!
Removed "Calc III" from thread title -- this is really a precalc type of problem. Also moved thread to the precalc forum section.
How is this a pre-calc problem if I'm in calc 3 and this is the first time that I've dealt with this? Did my university just not cover this? Or am I behind?
Vectors in R2 and R3 are often covered in precalculus with trig courses.
No limits, no derivatives, no integrals = no calculus.
Your calc 3 course may simply be providing a refresher on basic vector math before jumping into vector calculus.
