Finding Velocity at B Using Kinetics and Work-Energy Principle
The discussion revolves around finding the velocity at point B of a system involving pulleys, using both kinetics and the work-energy principle. Participants are attempting to solve a homework problem that requires them to derive the velocity through two different methods: kinematics and work-energy analysis. The conversation includes various equations and assumptions related to the forces and motions involved in the system.
  • Homework-related
  • One participant calculated the acceleration at B and found the velocity at A to be approximately 1.256980509 using the equation v² = 2ad.
  • Another participant confirmed the same velocity for B using kinematics and expressed the need to match this with the work-energy approach.
  • Concerns were raised about the clarity of the problem statement and whether finding the velocity at B was indeed the correct goal.
  • Assumptions about starting from rest and the role of gravity were discussed, with some participants agreeing on these points.
  • Discrepancies in the application of the work-energy principle were noted, including potential missing terms and negative signs related to gravity.
  • Participants debated the necessity of including moments in their calculations, with differing opinions on whether they should be accounted for in the energy equations.
  • One participant pointed out that the distances traveled by different parts of the system may not be the same, suggesting a need for adjustments in the equations used.
  • Another participant acknowledged the need for corrections and refinements in their calculations, indicating ongoing uncertainty in reaching a final answer.
Participants generally agree on the methods to be used (kinematics and work-energy) but have not reached consensus on specific details such as the inclusion of moments, the correct application of distances, and the overall approach to solving the problem. The discussion remains unresolved with multiple competing views and ongoing refinements.
Limitations include potential missing assumptions regarding the forces acting on the system, the dependence on the definitions of terms used, and unresolved mathematical steps related to the work-energy principle. The scope of the discussion is also limited by the specific changes made to the original problem statement by the teacher.
zack7
I have to solve this question in two ways, the first is from kinetics and kinematics and the second from the principle of work and energy. For the the first problem I obtained 3.160643122 for the acceleration at b(pulley with force t) and proceeded to find to find the velocity at a which I found out to be v = 1.256980509 by using v2=2ad
I then proceed to use the principle of work and energy but can never match the answers. I am not sure where I am going wrong.
The goal is to find the velocity at velocity at B(second pulley/pulley with force T)
Note the question changed a little with the force T moving upward 6 inches
Basically by using kinematics and Newton's Equations I came to the answer that the velocity of B the (second pulley with T force ) is 1.256980509 by using v2=2ad
Then I would have to use the principle of work and energy to find out the same velocity which should be the same as question 1
F ds +Ʃ M dθ=[itex]\frac{1}{2}[/itex]mv2+[itex]\frac{1}{2}[/itex]IW2
Kinematics
V=wr
FA+([itex]\frac{1}{2}[/itex])(ma+mc)gA+(mbgA)=[itex]\frac{1}{2}[/itex](ma+mc)V2f+[itex]\frac{1}{2}[/itex]mbv2f+[itex]\frac{1}{2}[/itex]IbW2+[itex]\frac{1}{2}[/itex]IaW2
a=pulley with weight
b=pulley with T force
c=weight
A=distance traveled by the pulley
hi zack7! :wink:
thanks for the pm
your work is very difficult to read, can you please type it? :smile:
Glancing at this, my initial reaction is that you should not be getting velocity numbers or distances. Why is the goal to find the velocity at B? That's not what the question is asking for in the book.
I'm going to work the problem right now and let you know what I find.
My teacher changed the question up a little bit and we have to find the velocity of B with the force T when it moves up 6 inches.
Gotcha gotcha. I thought maybe that was what it was. I'm assuming it starts from rest (safe to assume). I'm also assuming gravity is in this problem (although it doesn't have to be).
Kinematics
V=wr
c=weight
Your kinematic approach looks excellent, although I haven't cranked out the numbers or checked all your subscripts carefully. You've put in a lot of good work.
For the energy approach, looks like you slipped a minus sign, regarding the work done by gravity. And what happened to the M dθ term?
My teacher said that since no moment was applied it would be zero
The good news: our answers are somewhat close which in a problem like this is probably a good thing.
I got 1.77776 ft/s for vB (which means vA is .88888 ft/s=.5*vB)
Using work: The work from the tension adds energy which becomes PE, KE, and rotational KE.
Simple equation (I converted the 3 masses to slugs and used 32.2 ft/s for gravity and converted all lengths to feet. Note 6 inches=.5 feet. Sorry, I had to leave units out of calculations for speed. I also use parentheses for multiplication. I=.022 r=.3333):
work: 15*.5=Wtension=
PE: +10(.5).5 +10(.25).5 +20(.25).5
KE: +.5(mpulley)vB^2+.5(mpulley)(.5*vB)^2+.5*mass*(.5*vB)^2
RotKE: +.5(I)(vB/r)^2 +.5(I)(.5*vB/r)^2+0
which the calculator or computer program can solve quickly
I need to look at your work more tomorrow and finish my work as well. When is your homework due? Hope I'm not too late.
(edit: fixed wrong units. no change in the numbers.)
Ugh. I forgot the M dθ term. I agree with PhantomJay. I need to fix that tomorrow. Your teacher says there is none, hmmmm. I'm not so sure.
I got 1.77776 m/s for vB (which means vA is .88888 m/s=.5*vB)
Using work" The work from the tension adds energy which becomes PE, KE, and rotational KE.
That is great and your are not late, I will compute it, and thank you for the help
It seems to me that the applied force F produces moment about the center of the top pulley.
Actually I'm going with his teacher (again) now. The ropes cause moments on both pulleys but that gets accounted for in the [itex]\frac{1}{2}[/itex]IbW2+[itex]\frac{1}{2}[/itex]IaW2 terms. The rotational positions of the pulleys don't have different energy levels so no Mdθ terms are needed in this case I feel. Quick analogy: if you push a block on a frictionless horizontal surface, all the work done goes into KE. Similar for the pulleys.
What do you think PhantomJay? Mdθ terms still needed?
Edit: I see. You can use the moment to calculate how much work is done on the pulleys. The problem is the moment is unknown because the ropes that go around the pulleys change tension some. Simpler to go from the work put into the whole system becomes PE, KE, and rotationalKE in this linked system. Mdθ will come up in different methods.
Phantom Jay correctly pointed out missing negative signs because gravity force is down. Found something else too though. In your attached work and in this equation, the distances traveled are messed up some. Notice that the rope end with the force travels the farthest. It does not travel the same distance as pulley B which is what you have in your equation. FA should be 2*FA (if I understand correctly that F is the tension).
Agree zack7?
Agree zack7?
Yup that makes sense and after incorporating the negative and the distance traveled, I am getting close to the answer but still am no able to find one. It seems it I am missing a term or I am not doing the work done part properly.
I looked at your formula on the computer screen and plugged it into the my TI-89 and used the solve function and got 1.77776. Worked for me. I would rewrite you equation with corrections. I think your subscript on a moment of inertia might be incorrect. And the way the linear velocity terms are written could lead to error. (mc)V2f+[itex]\frac{1}{2}[/itex]mbv2f. Note that Vf does not equal vf here.
Similar issue on W and W. Those two are different but with same variable. Caution caution caution on that.
The W for the pulley from the bottom would be [itex]\frac{v}{2R}[/itex] and the other [itex]\frac{v}{R}[/itex]
2FA-([itex]\frac{1}{2}[/itex])(ma+mc)gA-(mbgA)=[itex]\frac{1}{2}[/itex](ma+mc)2V2f+[itex]\frac{1}{2}[/itex]mbv2f+[itex]\frac{1}{2}[/itex]IbW2+[itex]\frac{1}{2}[/itex]IaW2
Is that how you did it ? I did it this way and got 1.265
At first even for my kinematics approach I got 1.777 when I used d=d but I thought it would move half of the rope therefore d= d/2 , which is how I got the 1.25 and I am getting 1.26 using the approach above.
Here is my other method:
The letters in the picture mean tensions.
k=mass pulley. l=mass of the hanging mass. AA=acceleration of A and hanging mass. AB=acceleration of B. Parentheses often used as multiplication.
I drew a free body diagram (of both pulleys) with linear inertial force and rotational inertia force. I used the picture to do the sum of y forces which equals 0. This gives two equations.
0=(-H-T)+U+(10+k*AB)
0=(-E-U)+(20+l*AA)+(10+k*AA)
Now (T-H)r=a torque=I(alphaB)=I(AB/r) which means H=-(I*AB/r^2-T)
and (U-E)r=I(AA/r) which means E=-(I*AA/r^2-U)
and AB=2*AA
Substitute
0=((I*2AA/r^2-T)-T)+U+(10+k*2*AA)
0=((I*AA/r^2-U)-U)+(20+l*AA)+(10+k*AA)
Using a some sort of solver
AA=3.16045 ft/s^2 and U=16.7852 lb
means AB=6.3209 ft/s^2
acceleration=AB
velocity=AB*t+0
position=.5*AB*t^2+0+0
position=.5*.5 which means t=.281252 sec
which means velocity=1.77777 ft/s which agrees as it should
A .01 difference could be rounding but I don't think 1.265 or 1.25 is correct.
Also I tried solving the new equation and I got 1.016 (and 1.295 with a slight change) but never 1.265. Solving mistake??
You put a 2 before Vf which should be .5 and should be (.5*Vf)^2 not 2*Vf^2 and not (2*Vf)^2.
Yup the velocity should be 1.77, but I just can't seem to get it with the equation below
2FA-([itex]\frac{1}{2}[/itex])(ma+mc)gA-(mbgA)=[itex]\frac{1}{2}[/itex](ma+mc)(0.5V)2f+[itex]\frac{1}{2}[/itex]mbv2f+[itex]\frac{1}{2}[/itex]IbW2+[itex]\frac{1}{2}[/itex]IaW2
Going off what was on the screen, I got it. Make sure to do (v/(2*r))^2 not (v/2r)^2. This formula looks good to me.
Use A=.25 ft
Use A=.25 ft
For the right hand side I got 0.397137375v2
for the left I got 7.5-6.250498975-2.499999995=-1.250498
used A=0.25ft, R=(1/3)ft ,I=0.0222
Good news. You're very very very close.
I could get -1.25 by switching the .5 to the third term (not that you did that). The number should be +1.25.
-6.2505 is miscalculated.
(Also I did get .39551 v^2 but my number and your number are close enough.)
I'd advise using a solver. I believe algebra mistakes happen not because people don't know algebra but because they get tired and make careless errors. For me I don't want to make careless errors. But maybe even more importantly I don't want to waste time.
Why kind of calculator do you have?
Yup used Matlab and got the same answer.
Thank you
The work put into the system by both conservative and non conservative external forces is equal to the change in the kinetic energy of the system. That is the work energy principle. Or using conservation of energy , the work done by external non conservative forces is equal to the change in the potential and kinetic energy of the system. Either approach may be used, and either approach includes both rotational and translational kinetic energy and rotational and translational work. When calculating the work done by external non conservative forces, one must include the rotational work done by the moment of the applied external force F, F(R), acting over the angular displacement of the top pulley, d/R . I am not sure why you are getting the kinematic and energy approaches to agree without accounting for this. Maybe someday I'll do the math when i have more patience to crank out the numbers!
EDIT: ohhhh my apologies you are right. Although the applied external force and weights do translational work, the moment from the forces are all internal to the system, and thus do not do external rotational work. Sorry for any confusion I may have caused.
  • · Replies 48 ·
  • · Replies 58 ·
