Finding velocity given radius and coefficient of friction
To determine the speed at which a 2kg box slips off a circular platform with a radius of 6.0m and a coefficient of friction of 0.3, one must analyze the forces acting on the box. The key point is that slipping occurs when the frictional force can no longer provide the necessary centripetal force. The discussion emphasizes that the acceleration is not provided, suggesting that the focus should be on the balance between centripetal force and friction. While some participants argue about the relevance of non-uniform circular motion, the consensus leans towards simplifying the problem by treating tangential acceleration as negligible. Ultimately, the solution hinges on equating the centripetal force to the frictional force to find the critical speed.
Mooshk
A box with mass 2kg is on the edge of a circular platform of radius 6.0m. The coefficient of friction between the platform and the box is 0.3. The platform accelerates. Determine the speed when the box slips off the edge.
Fs = μsN
F⃗ net=ΣF⃗ =ma⃗
a(t) = d(vt)/dt
a(r) = v^2/r
a = [sqrt (ar^2) + (at^2)]
I know that this is non-uniform circular motion.
I don't think that what I'm doing is right.
ΣF(t) = -Ff = m(at)
at = - μs(g)
a(t) = - (0.3)(9.8)
a(t) = -2.94 m/s^2
ΣF(r) = m(ar)
ΣF(r) = (mv^2) / r
ΣF(net) = m * [sqrt (ar^2) + (at^2)]
Ff = m * [sqrt (ar^2) + (at^2)]
μs(g) = [sqrt (μs^2(g^2)) + (m^2*v^4) / r^2]
(μg)^2 = (μs^2(g^2)) + (m^2v^4) / r^2
((μg)^2 - μs^2(g^2)) /r^2 = (m^2*v^4)
So if I solve for v, I would take the fourth root of the left side after bringing m^2 over, and that doesn't seem right to me.
I think you are working too hard. The acceleration is not given, suggesting you ignore F = ma. To my mind, it sounds like the condition for beginning to slip is simply when friction can no longer provide the necessary centripetal force to hold it on:
centripetal force = force of friction
which easily solves for v.
How would that model non-uniform circular motion? Or does that not matter since the friction force is perpendicular?
Strictly speaking, it does not apply to non-uniform circular motion where it could be that high tangential acceleration will cause the thing to slip into kinetic friction mode before centrifugal force overcomes the grip. If you have been doing problems like that in class, then do it with this one, too. Note that you will have to consider the combined radial and tangential forces and calculate when that exceeds the friction force.
But the wording suggests to me that the tangential acceleration is so small it can be ignored and slipping will occur in the radial direction.
  • · Replies 30 ·
22K
  • · Replies 20 ·
