Finding velocity when acceleration is a = 5.0t
  • Thread starter Thread starter B-80
    Dynamic
11 replies · 5K views
B-80
The acceleration of a particle along an x-axis is a = 5.0t, with t in seconds and a in meters per second squared. At t = 2.0 s, its velocity is +13 m/s. What is its velocity at t = 6.5 s?
I don't really know how to go about this, as it is a dynamic acceleration, any help would be greatly appreciated
so far all I have got is a=deltaV/deltaT
That's OK for average acceleration, but for instantaneous acceleration use a derivative: [itex]a = dv/dt[/itex].
Given acceleration, how do you find velocity? Hint: Use a little calculus.
well I would multiply by the time passage, but again this only works for constant acell right? my problem is the derivative, I know how to do them, but i don't understand how that applies. the derivative of a is 5 right? that's great, but what do I do after that
If you were given v, you'd take its derivative to find a. But you have the opposite situation: You are given a and need to find v. What do you do?
B-80 said:
integrate? so 2.5t^2=v
Good! But don't forget the constant of integration.
Finding position
I have run across the same type of problem, but I am being asked what the position is. Below is what was given.
Acceleration of a point is a=20t m/s^2. When t=0, s=40 meters and v=-10 m/s. What is the position at t=3 sec?
I've used a=dv/dt to get the velocity, v=80 m/s.
I'm not sure were to start to get the position. Can you advise?
Thank you.
Using a=dv/dt, you integrated to get the velocity. But v = dx/dt, so integrate once again to get the position.
For velocity I got v=10t^2 + c, and pluged 3 in for t and -10 in for c. This gave me v=80 m/s.
If i integrate once more to get position I get s=(10t^3)/3+ct.
Am I correct with the constant?
Plug 3 in for t, and -10 in for c again.
I think I am getting confused with the constant.
That's the velocity at t = 3; in general it's: v=10t^2 - 10.
But you forgot the new constant of integration. (Hint: You are given the position at t = 0.)
Thats what I was forgetting.
Therefore s=(10t^3)/3+ct+d.
Where
t=3
c=-10
d=40
Thanks for the help.
