Finding Voltage Gain: Help with Homework
  • Thread starter Thread starter CoolDude420
    Gain Voltage
8 replies · 2K views · last reply
CoolDude420
I can't seem to figure out the answer. Apparently, the right method involves saying that Vs is actually equal to the voltage Vgs + voltage across R1. I don't understand how Vs could be voltage across R1?
This is what I have so far
I think the first two bullet points that I wrote are correct but 99% sure that the circuit transformation I did is completely wrong.
I wouldn't call Rs a short circuit just because there is no current through it!
Vs = voltage across Rs + Vgs + voltage across R1
because these voltages are in series between the point where the potential is Vs and the point where the potential is zero volts (ground)
Oh. I see. So you're sort of looking at it like this. And that's how u found out what Vs breaks down into
Arrow doesn't mean current.
Yes. For every path traced between 2 nominated points, the total potential will be equal.
Great! Thank you very much. I think I should be able to get it from here.
I take that statement back. I'm stil stuck :(
I just went in a full circle back to the equation I started with...
NascentOxygen said:
Express VR1 in terms of the current through it.
I suggest you go back just one step.
You have a dependent source (gmVgs) that relies on an internal voltage (vgs). you need to relate that internal voltage to component values and independent sources.
Write out the expression as Vgs =? as a function of Vs, gm, R1, and constants.
Once you get that expresion, you already stated that the output is -gmVgsR2, you should be able to solve for your transfer function Vo/Vs. You're very close
Also just a note, pay attention to this model, it will become more important as you learn more about circuitry. It is the small signal model for a type of transistor, a MOSFET
