Finding volumes by rotating around an axis of revolution
This discussion focuses on calculating the volume of a sphere using integration techniques, specifically revolving around the line y=1. The integral setup involves the equation 2π∫(y-1)²√(25-(y-1)²) dy from 1 to 6. The user initially attempted to find the volume using a combination of substitution and trigonometric identities, ultimately arriving at an approximate answer of 25π² + 499.89π/3, while the expected result is 25π² + 500π/3. Key insights include the importance of correctly setting up the integral and the use of trigonometric substitution for simplification.
  • Understanding of integral calculus, particularly volume calculations via rotation.
  • Familiarity with trigonometric substitution methods in integration.
  • Knowledge of the geometric properties of spheres and cylinders.
  • Proficiency in manipulating algebraic expressions and limits of integration.
  • Study the method of cylindrical shells for volume calculations.
  • Learn about trigonometric substitution in integral calculus.
  • Explore the derivation of volume formulas for spheres and cylinders.
  • Practice solving integrals involving square roots and polynomial expressions.
Students and educators in calculus, mathematicians focusing on geometric applications, and anyone interested in mastering volume calculations through integration techniques.
Sidthewall
1. Homework Statement
k so here is the equation i need help with that will find me the volume of a sphere
2*pi*y*sqrt(25-(y-1)^2) dy - 5*pi from 0 to 6
the 5 pi is the volume of a cylinder
2. Steps
so first i subbed u=y-1
took the 2 pi out of the integral
that got me 2 integrals u*sqrt(25-(u)^2) du + sqrt(25-(u)^2) du
the first integral = (2*pi*24^(3/2))/3
the second i used a trig sub and my final answer is
(25pi^2)/2 +
-25*asin(-.2)+sqrt(24)
3. Answer
the answer is suppose to be 25pi^2 + 500pi/3
i got 25pi^2 + (-75*asin(-.2)+3*sqrt(24)+2*(24)^(3/2) -15)/3
which is approx
25pi^2 + 499.89pi/3
how do i get the exact answer
You are trying to find the volume of a sphere of radius 5 with center at (0, 1, 0)? Projected onto a x, y plane, gives the circle x^2+ (y- 1)^2= 25 and taking only the right half-plane, x= \sqrt{25- (y-1)^2}. That is the figure being rotated around the line y= 1.
And, from the way you are doing this, I take it you are using "cylinders" (I would have been inclined to use disks). Each "cylinder" of radius y has length
\sqrt{25- (y- 1)^2}- (-\sqrt{25- (y-1)^2})= 2\sqrt{25- (y- 1)^2}
and so surface area \pi r^2h= \pi (y- 1)^2(2\sqrt{25- (y-1)^2}). With "thickness" dy, each cylinder will have volume 2\pi (y- 1)^2\sqrt{25- (y-1)^2} dy so the volume of the entire sphere will be the integral, as y goes from 1 to 1+ 5= 6,
2\pi \int_1^6 (y- 1)^2\sqrt{25- (y- 1)^2}dy
A good first step, just as you say, would to be let u= y- 1 so that du= dy, when y= 1, u= 0, when y= 6, u= 5 and the integral becomes
2\pi\int_0^5 u^2\sqrt{25- u^2}du
Yes, you can let u= 5sin(\theta) so that du= 5 cos(\theta)d\theta and \sqrt{25- u^2}= \sqrt{25- 25sin^2(\theta)}= 5\sqrt{cos^2(\theta)}= 5 cos(\theta). Further, when u= 0, 5sin(\theta)= 0 so \theta= 0 and when u= 5, 5 sin(\theta)= 5 so \theta= \pi/2.
The integral becomes
2\pi\int_0^{\pi/2}(25 sin^2(\theta))(5 cos(\theta))(5 cos(\theta))d\theta[/itex]<br /> <br /> I do not know why you are using &quot;y&quot; outside the square root rather than &quot;y- 1&quot; nor do I see why it is not squared. I had to guess at what you really intended since you did not say what the radius or center of the sphere were. I also do not know why you subtracted 5\pi, the &quot;volume of a cylinder&quot; when you said you were finding the volume of a sphere.
no no... sorry the circle is being revolved around the x-axis and y2= 1 which is why so the 5pi exists because i am subtracting the volume from y2
oh and yes amd the question asked me to revolve the circle around the x-axis in terms of y, which is longer by the way.
<br /> 2\pi \int_0^6 y\sqrt{25- (y- 1)^2}dy + 5\pi<br />
that's the integral I want solved and the answer i got is (25pi^2)/2 + (500*pi)/3 intstead of 25pi^2 + 499.89pi/3
  • · Replies 27 ·
  • · Replies 20 ·
