Finding wire diameter given mass, resistance, and resistivity
3 replies · 7K views · last reply
pkujulo2
Suppose you wish to fabricate a uniform wire from a mass m of a metal with density [tex]\rho[/tex]m and resistivity [tex]\rho[/tex].
If the wire is to have a resistance of R and all the metal is to be used, what must be the
a)length and
b) the diameter of this wire?
(Use any variable or symbol stated above as necessary.)
[tex]\rho[/tex] - resistivity,l -length, r -radius, m - mass, d - density.
a)
R = [tex]\rho[/tex] l/A
d = m/Al
l = Rm/ d[tex]\rho[/tex]
b) A = [tex]\pi[/tex]r^2 =[tex]\rho[/tex]
a)I have done this part already and got the question right
For this I ended up solving for l^2 and getting:
l = sqrt( (Rm) / ([tex]\rho[/tex]m*[tex]\rho[/tex]) )
b) for the cross sectional area, I used [tex]\pi[/tex]*r^2 and substituted that for [tex]\pi[/tex]*(d/2)^2
And I responded with the following answer that was marked incorrect:
d = sqrt( (4[tex]\rho[/tex]l) / [tex]\pi[/tex]*R )What did I do wrong for b)?
By the same token as (a), in which you solved for A=m/(L*density), you can say:
L=m/(A*density)
Then R=(rho*m)/(density*A2)
Solve for A, and then also note A=Pi*diameter2/4
I got a double radical as an answer, but the units under the second radical was m4, which indeed, raised to the (1/4) is meters for diameter.
pkujulo2 said:
R = ρ ℓ/A
d = m/Aℓ
Solve one of the the above equations for A and substitute the value you got for ℓ.
Then solve A = π(a/2)2 for d substitute the previous value for A into that.
As Apphysicist said, you should have a radical of a quantity with a radical.
