Finding Zeros of System Function using Eigenvalues
4 replies · 2K views
DSRadin
Hi all - working on this problem wanted to see if anyone had any advice - thanks!
As shown in section 4.4, the poles of the system [itex]H(z)[/itex] with state matrices [itex]\mathbf{A, b, c^t, } d[/itex] are given by the eigenvalues of [itex]\mathbf{A}[/itex].
Find: Show that, if [itex]d\neq0[/itex], the zeros of the system are given by the eigenvalues of the matrix [itex]\left (\mathbf{A}-d^{-1}\mathbf{b}\mathbf{c^t} \right )[/itex].
Hint: The poles of the inverse system [itex]H^{-1}(z)[/itex] equal the zeros of [itex]H(z)[/itex], and [itex]H^{-1}(z)[/itex] has the output [itex]x(n)[/itex] if its input is [itex]y(n)[/itex].
2. [itex]H(z)=\mathbf{c^t}(\mathbf{zI-A})^{-1}\mathbf{b}+d[/itex]
3. I understand why the poles of the system are eigenvalues of A. I have gone through this derivation in other work. I feel like there is something I am missing in the linear algebra that would simplify this problem. My attempt at a solution below stops short of solving for eigenvalues of the new matrix because i feel that proving this in generality must be cleaner than this brute force method.
[itex]H^{-1}(z)=\left [\mathbf{c^t}(\mathbf{zI-A})^{-1}\mathbf{b}+d \right ]^{-1}[/itex]
[itex]\left ( \mathbf{A}-d^{-1}\mathbf{bc^t} \right ) = \left (\begin{bmatrix}<br /> a_{1 1} & \cdots & a_{1 N-1} \\<br /> \vdots & \ddots & \vdots \\<br /> a_{N-1 1} & \cdots & a_{N-1 N-1}<br /> \end{bmatrix} - \begin{bmatrix}<br /> \frac{b_1c_1}{d} & \cdots & \frac{b1c_{N-1}}{d} \\<br /> \vdots & \ddots & \vdots \\<br /> \frac{b_{N-1}c_1}{d} & \cdots & \frac{b_{N-1}c_{N-1}}{d}<br /> \end{bmatrix}\right ) = \begin{bmatrix}<br /> a_{1 1} - \frac{b_1c_1}{d} & \cdots & a_{1 N-1} - \frac{b1c_{N-1}}{d} \\<br /> \vdots & \ddots & \vdots \\<br /> a_{N-1 1} - \frac{b_{N-1}c_1}{d} & \cdots & a_{N-1 N-1} - \frac{b_{N-1}c_{N-1}}{d}<br /> \end{bmatrix} = \mathbf{A'}[/itex]
And then some eigen decomposition leads towards...
[itex]|\mathbf{A'}-\lambda\mathbf{I}|=0 = det\begin{bmatrix}<br /> a_{1 1} - \frac{b_1c_1}{d}-\lambda & \cdots & a_{1 N-1} - \frac{b1c_{N-1}}{d}-\lambda \\<br /> \vdots & \ddots & \vdots \\<br /> a_{N-1 1} - \frac{b_{N-1}c_1}{d} -\lambda & \cdots & a_{N-1 N-1} - \frac{b_{N-1}c_{N-1}}{d}-\lambda<br /> \end{bmatrix}[/itex]Is there something in the composition of [itex]\mathbf{A,b,c^t,} d[/itex] that I am missing?
Thanks all.
Just using the equation is the cleanest method I know of.
if you use MATLAB this method is extremely easy to implement.
I just want to note that you made an error in your step #3
Thank you for your response donpacino.
Unfortunately I'm not seeing it. (both the way to implement the equation and the error in 3)
I considered MATLAB but I was hesitant to take a deterministic approach and go with "if it works this once it will always work" kind of deal. Maybe i'l do that.
I= the identity matrix, which means the diagonal is equal to 1, and zero everywhere else
I=
[1 0 0
0 1 0
0 0 1]
so if A=
[1 1 1
1 1 1
1 1 1]
then |A-λI|=
[1-λ, 1, 1;
1, 1-λ , 1;
1, 1, 1-λ]
does that make sense?
doh! Yes absolutely it makes sense.
I got the answer now too - the key was to back it into state space equations and re-solve.
Thank you for the response!
-DR
