Finding Zeros of System Function using Eigenvalues
The discussion revolves around finding the zeros of a system function using eigenvalues, specifically in the context of state-space representations in control theory. Participants explore the relationship between the poles and zeros of the system, as well as the implications of the state matrices involved.
  • Homework-related
  • One participant notes that the poles of the system H(z) correspond to the eigenvalues of the matrix A and seeks to demonstrate that the zeros are given by the eigenvalues of the matrix (A - d-1bct).
  • Another participant suggests that using MATLAB could simplify the implementation of the equations involved, although they point out an error in the previous participant's step #3.
  • A participant expresses uncertainty about the error mentioned and considers the deterministic nature of using MATLAB for solving the problem.
  • One participant explains the concept of the identity matrix and provides an example of calculating the determinant of a matrix involving eigenvalues.
  • A later reply indicates that the participant found the answer by re-evaluating the problem in the context of state-space equations.
Participants do not reach a consensus on the error in the calculations, and there is a mix of approaches suggested, including both analytical and computational methods. The discussion reflects uncertainty and varying perspectives on the best method to solve the problem.
Some participants express concerns about the generality of the methods used and the implications of relying on computational tools without fully understanding the underlying mathematics.
DSRadin
Hi all - working on this problem wanted to see if anyone had any advice - thanks!
As shown in section 4.4, the poles of the system H(z) with state matrices \mathbf{A, b, c^t, } d are given by the eigenvalues of \mathbf{A}.
Find: Show that, if d\neq0, the zeros of the system are given by the eigenvalues of the matrix \left (\mathbf{A}-d^{-1}\mathbf{b}\mathbf{c^t} \right ).
Hint: The poles of the inverse system H^{-1}(z) equal the zeros of H(z), and H^{-1}(z) has the output x(n) if its input is y(n).
2. H(z)=\mathbf{c^t}(\mathbf{zI-A})^{-1}\mathbf{b}+d
3. I understand why the poles of the system are eigenvalues of A. I have gone through this derivation in other work. I feel like there is something I am missing in the linear algebra that would simplify this problem. My attempt at a solution below stops short of solving for eigenvalues of the new matrix because i feel that proving this in generality must be cleaner than this brute force method.
H^{-1}(z)=\left [\mathbf{c^t}(\mathbf{zI-A})^{-1}\mathbf{b}+d \right ]^{-1}
\left ( \mathbf{A}-d^{-1}\mathbf{bc^t} \right ) = \left (\begin{bmatrix}<br /> a_{1 1} &amp; \cdots &amp; a_{1 N-1} \\<br /> \vdots &amp; \ddots &amp; \vdots \\<br /> a_{N-1 1} &amp; \cdots &amp; a_{N-1 N-1}<br /> \end{bmatrix} - \begin{bmatrix}<br /> \frac{b_1c_1}{d} &amp; \cdots &amp; \frac{b1c_{N-1}}{d} \\<br /> \vdots &amp; \ddots &amp; \vdots \\<br /> \frac{b_{N-1}c_1}{d} &amp; \cdots &amp; \frac{b_{N-1}c_{N-1}}{d}<br /> \end{bmatrix}\right ) = \begin{bmatrix}<br /> a_{1 1} - \frac{b_1c_1}{d} &amp; \cdots &amp; a_{1 N-1} - \frac{b1c_{N-1}}{d} \\<br /> \vdots &amp; \ddots &amp; \vdots \\<br /> a_{N-1 1} - \frac{b_{N-1}c_1}{d} &amp; \cdots &amp; a_{N-1 N-1} - \frac{b_{N-1}c_{N-1}}{d}<br /> \end{bmatrix} = \mathbf{A&#039;}
And then some eigen decomposition leads towards...
|\mathbf{A&#039;}-\lambda\mathbf{I}|=0 = det\begin{bmatrix}<br /> a_{1 1} - \frac{b_1c_1}{d}-\lambda &amp; \cdots &amp; a_{1 N-1} - \frac{b1c_{N-1}}{d}-\lambda \\<br /> \vdots &amp; \ddots &amp; \vdots \\<br /> a_{N-1 1} - \frac{b_{N-1}c_1}{d} -\lambda &amp; \cdots &amp; a_{N-1 N-1} - \frac{b_{N-1}c_{N-1}}{d}-\lambda<br /> \end{bmatrix}Is there something in the composition of \mathbf{A,b,c^t,} d that I am missing?
Thanks all.
Just using the equation is the cleanest method I know of.
if you use MATLAB this method is extremely easy to implement.
I just want to note that you made an error in your step #3
Thank you for your response donpacino.
Unfortunately I'm not seeing it. (both the way to implement the equation and the error in 3)
I considered MATLAB but I was hesitant to take a deterministic approach and go with "if it works this once it will always work" kind of deal. Maybe i'l do that.
I= the identity matrix, which means the diagonal is equal to 1, and zero everywhere else
I=
[1 0 0
0 1 0
0 0 1]
so if A=
[1 1 1
1 1 1
1 1 1]
then |A-λI|=
[1-λ, 1, 1;
1, 1-λ , 1;
1, 1, 1-λ]
does that make sense?
doh! Yes absolutely it makes sense.
I got the answer now too - the key was to back it into state space equations and re-solve.
Thank you for the response!
-DR
