Proving Cyclic Finite Abelian Groups of Order pn
  • Thread starter Thread starter Kalinka35
    Finite Groups
An abelian group of order pn, where p is a prime, contains p-1 elements of order p, indicating it must be cyclic. The discussion explores the structure of finite abelian groups and rules out configurations that would yield more than p-1 elements of order p. It emphasizes that if any component in the direct product has a higher power of p, it will lead to additional elements of different orders. The correct counting of elements of order p in Zp^x reveals that there are indeed p-1 such elements, supporting the conclusion that the group is cyclic. Ultimately, the reasoning confirms that the group must be cyclic based on the given conditions.
Kalinka35
An abelian group has order pn (where p is a prime) and contains p-1 elements of order p. Prove that this group is cyclic.
I know I should use the theorem for classifying finite abelian groups, which I understand, and I feel like I have all the pieces but I don't know how to put them together.
Ok, so what are some possibilities for the structure of an abelian group of order p^n? Can you rule some of them out based on the order p condition?
The only case I've managed to definitively rule out is the case where in
Zm1 x Zm2 x ... x Zmk we set k=n and m1=m2=...=p. In each of Zm1 through Zmk there are p-1 elements of order p so taking the direct product of all these you certainly end up with more than p-1 elements of order p.
In the case where any of m1,..., mk are equal to some p^x where x>1 and k>1 then in some Zmi there will be p^(x-1) - 1 elements with order not equal to p. I'm not sure that is entirely correct but if so then taking direct product we will end up with more than p-1 elements of order p and we'll conclude that the group has to be cyclic.
You've got the right idea but I'm not sure you are counting correctly. How many elements of order p in Zp^x??
Well, aren't the elements of order p the ones that are not divisible by p? That was what I was trying to count before. Although looking it over again I would say that there are px-px-1 elements of order p.
An element a of order p in Zp^x satisfies the conguence a*p=p^x. How many factors of p does a have to have?
Oh okay. So there are x-1 factors of p in a. So I guess this gives you that there are p-1 elements of order p since you can only multiply p^(x-1) by numbers less than p until you get p^x and the rest of the argument would be similar to the first one for setting all of the m's equal to p.
Thanks.
