How Do You Solve for Position x(t) Given a Force Dependent on Velocity?
  • Context: Undergrad
  • Thread starter Thread starter hanilk2006
    First order Ode
The discussion focuses on solving for the position x(t) of a particle subjected to a force defined by F(v) = bv², where b is a constant and v is the velocity. The initial conditions are set with an initial position of zero and an initial speed of v_i. The participants derive the equation m*dv/dx*v = -bv² and discuss the integration process, emphasizing the importance of correctly applying constants during integration. The constants represent the initial conditions, with the lower limits corresponding to the initial position and velocity.
  • Understanding of Newton's second law of motion
  • Familiarity with calculus, specifically integration techniques
  • Knowledge of differential equations
  • Basic concepts of kinematics and dynamics
  • Study the application of Newton's second law in non-linear force scenarios
  • Learn advanced integration techniques for solving differential equations
  • Explore the relationship between velocity and acceleration in particle motion
  • Investigate the implications of force-dependent velocity on motion dynamics
Students and professionals in physics, particularly those studying mechanics, as well as engineers and mathematicians dealing with motion dynamics and differential equations.
hanilk2006
A particle of mass m is subject to a force F(v) = bv^2. The initial position is zero, and the initial speed is vi find x(t)
so far
m*dv/dx*v = -bv^2
m*dv/dx = -bv
integral m/-bv*dv = integral dx
m/-b*ln(v) + a = x + b
What do I do with the constants? i thought i was suppose to put in 'a' as vi and b as 0, but then when i integrate again for v, so i can get x(t) function, what do i use to fill in that constant?
Where does m*dv/dx*v = -bv^2 come from? Newton's second law of motion implies F=m*dv/dt.
dv/dx*v=dv/dx*dx/dt = dv/dt = a
OK. You use your constants in the integrations: the lower constant on the dx integral is the starting location = 0, and the lower constant on the dv integral is the initial velocity = v_i.
The upper constants are the unknowns ... your integral equation will provide a relation between them.
  • · Replies 63 ·
  • · Replies 17 ·
