Calculate Torque Exerted by Fish at 20° Angle
  • Thread starter Thread starter UrbanXrisis
    Torque
The torque exerted by a fish on a fishing pole at a 20° angle with the horizontal can be calculated using the formula T = rFsin(θ). In this discussion, the torque is determined to be 167.7 Nm when using the correct angle of 123° derived from the relationship between the angle of the fishing pole and the force applied. The calculations confirm that the angle of 20° affects the resultant angle used in the torque equation, emphasizing the importance of accurately determining θ for precise torque calculations.
  • Understanding of torque calculations using the formula T = rFsin(θ)
  • Basic knowledge of trigonometry, specifically sine functions
  • Familiarity with physics concepts related to forces and angles
  • Ability to interpret angles in relation to horizontal and vertical planes
  • Study the principles of torque in rotational dynamics
  • Learn about the application of trigonometric functions in physics problems
  • Explore the effects of different angles on torque calculations
  • Investigate real-world applications of torque in fishing and other sports
Physics students, engineering students, and anyone interested in understanding the mechanics of torque in practical scenarios, particularly in fishing and related activities.
UrbanXrisis
The fishing pole in the http://home.earthlink.net/~suburban-xrisis/clip.jpg makes an angle of 20 degrees with the horizontal. What is the torque exerted by the fish about an axis perpendicular to the page and passing though the fisher's hand?
Is this question basically asking about how much torque there is?
T=rFsinX
T=2m*100N*sin37
T=120Nm
is this all that the question is asking for?
torque = Fd sin(theta)
theta is the angle between the force and the fishing pole...
your theta is not quite correct, otherwise seems great
is theta 123 degrees?
Yes, it is 123 degrees. Optionally you could take 37 + 20 = 57 degrees. They have the same sin.
does the fact that the the fisher has a 20 degree angle with the hoizon? Will that make a difference in theta being 123 degrees?
Isn't the 20 degrees a completely different angle than the 123 degree angle?
yes but I'm wondering if I should take into account the 20 degrees above the horizontal... I shouldn't right? it shold just be...
T=rFsinX
T=2m*100N*sin123
T=167.7Nm
T=rFsinX
T=2m*100N*sin123
T=167.7Nm
Your answer is correct. But I don't understand what you mean by "taking the 20 degrees into account". If that angle wasn't 20, then theta wouldn't be 123.
For example if the angle was 30 instead of 20, then you'd be taking sin 113.
  • · Replies 28 ·
  • · Replies 22 ·
22K
