Fixed point iteration, locally convergent
14 replies · 3K views
John Harris
For which of them will the corresponding fixed point iteration xk+1 = g(xk) be locally convergent to the solution xbar in [0, 1]? (The condition to check is whether |g'(xbar)| < 1.)
A) 1/x2 -1
B)...
C)...
compute xbar to within absolute error 10-4.
3. The Attempt at a Solution
I[/B] don't think I understand the question in general terms, but this is what I think I have to do.
The solution xbar is 1 because g(1)=0. It's not locally convergent because |g'(1)|=-2
Since xbar isn't locally convergent I can't computer xbar. But calculating it would look like:
k | xk
1 1
2 -2
3 .25
4 128
Can you please help me understand what this problem is asking for, or similar examples of this problem, or what I'm doing wrong. Thank you
That is not a fixed point as your point changes (from 1 to 0) and the next iteration becomes impossible because you would have to divide by zero.
What does "fixed point" mean? What is fixed?
You'll have to check that again once you find the right xbar.
Oh sure you can, just not directly with the given iteration.
I'm guessing a fixed point is a point that can't change. My teacher said xbar is the solution, but I'm not sure of what and how to get it.
It does not change if you apply g to it, so the next iteration starts with the same value again. What does that mean in terms of equations?
Is it 0 because g(0)=0
mfb said:
##g(0)=\frac{1}{0^2}-1## is undefined.
Sorry I was thinking 2x for no reason.
I'm looking at the graph and all the values of x seem to have different y's. I'm not sure what I could put into g(x) that wouldn't change.
Where does the 1+51/2/2 come from in the attached picture.
I did fixed point iteration, but it's definitely not converging. I wish I knew what xbar is and how to get it.
Here's that image:
I would have never guessed this from the OP.
Apparently, ##\displaystyle\ \frac{1+\sqrt{5}}{2} \ ## is xbar and is a solution to the equation, g(x) = x .
SammyS said:
Here's that image:
That's the root of g'(x), but my problem doesn't have any roots, and my problem has an interval. So I have no idea.
Did you draw a sketch? You can get a rough idea where the fixed point is, and solve the equation numerically.
Yes I graphed it. I don't know what the I 'm looking for though. I tried the roots of the of f(x) and g'(x). And points close to the intersection of the graphs, but nothing is converging when I do it numerically.
edit:
I just tried it with another g(x) and it's converging to the root of f(x). So I'm pretty sure the root of f(x) is what I'm looking for and the original g(x) is not convergent.
What is f(x)?
It is not convergent, right, but it still has a fixed point. Can you write down the equation for the fixed point? What has to be true at this point? We said it in words, but you'll need the equation.
I take it that the image you posted, (and what I responded to), was for an example with the function ## \displaystyle \ g(x)=1+\frac{1}{x} \ ##. For this example problem, ## \displaystyle \ x_\text{bar}=\frac{1+\sqrt{5}}{2} \ ## because for that value of xbar, g(xbar) = xbar . In other words, xbar is a root of the equation, g(x) = x. (It's one of two roots.)
xbar is not a root (zero) of g'(x). Note that ## \displaystyle \ g'(x)=-\frac{1}{x^2} \ ## which has no root. However, as stated in the example, ## \displaystyle \ \left|g'(x_\text{bar})\right|<1 \, ,\ ## so the fixed point iteration gives a sequence converging to xbar for the example problem.
It's not entirely clear to me what the problem is that you're asked to solve. I guess that you're to do similarly for ## \displaystyle \ \frac{1}{x^2}-1 \ ## (or is it ## \displaystyle \ \frac{1}{x^2-1}\, ? \ ##) . It's likely the former since that gives xbar in [0, 1] .
Are you calling the function f(x) or calling it g(x) for your problem?
I figured it out. Thank for the help
