Flat Plate Deflection & stress - HDPE
This discussion focuses on analyzing flat plate deflection and stress for HDPE (High-Density Polyethylene) materials under hydrostatic water pressures. The main challenge is adapting existing formulas, typically based on steel with a Poisson's ratio of 0.3, to account for HDPE's higher Poisson's ratio of 0.38-0.4. The recommended approach involves using the same deflection formula with HDPE's modulus of elasticity and adjusting stress calculations by multiplying by a factor of 1.78, derived from the ratio of Poisson's ratios. It is advised to limit loads to less than 40% of the yield stress for safety.
  • Understanding of flat plate theory and hydrostatic pressure analysis
  • Familiarity with material properties, specifically HDPE's modulus of elasticity and Poisson's ratio
  • Knowledge of stress and deflection calculations in structural engineering
  • Access to Roark's Formulas for Stress and Strain, 7th Edition
  • Research the modulus of elasticity for HDPE and its impact on deflection calculations
  • Explore advanced methods for stress analysis in materials with varying Poisson's ratios
  • Learn about yield stress values for HDPE and their significance in load calculations
  • Investigate alternative resources or formulas for non-metallic materials in structural analysis
Structural engineers, materials scientists, and anyone involved in the analysis and design of HDPE structures under load conditions.
Antony S
Hi,
I'm trying to carryout some analysis of flat plates subjected to hydrostatic water pressures however the plate material is HDPE.
The problem I'm having is that all the formulae on the web and in Roark's 7th Edition are typical of steel with a Poisson's ratio of 0.3. I can't therefore find how to change the formulae or constants to account for the larger Poission's ratio that would be expected with HDPE (0.38-0.4).
To keep things simple I'm just considering a rectangular plate with fixed edges and a uniform UDL over the whole area as opposed to a triangulated load.
Can anybody offer advice on how best to deal with the stress and deflection of an HDPE plate?
Thanks in advance...
This is a good question. I know the errors in these formulas are no more than 3% for Poisson's ratio (PR) of 0.26 to 0.34 (REF: Machinery Handbook).
For the deflection, you can just use the same formula and the modulus of elasticity of HDPE.
For the stress, one possible method is as follows. From, the definition of PR, your HDPE will have a decease in diamater ("neck down") compared to PR=3 by the ratio: 0.4 / 0.3. So the area will decrease by the ratio: (0.4 / 0.3)^2 = 1.78.
Thus, for initial estimating, I would multiply the stresses you calculate by a factor of 1.78. Be sure to use a valid value of yield stress. And I would recommend limiting your loads to less than 40% yield stress.
EDIT:
I have a feeling my 1.78 factor on calculated stresses is too high (but will provide conservative results).
Thank you, this will be a good starting point.
17K
13K
9K
25K
