Flipping Functions: Determining Vertical/Horizontal Flips
  • Thread starter Thread starter soulmartyr
    Functions
6 replies · 3K views
soulmartyr
The problem shows two graphs, the first of which is just f(x)=3√x (square root of x cubed -not sure how to make it look like that-) and it wants me to give a function for the graph on the right.
The second graph is flipped, vertically shifted 1 up f(x)+ 1 and horizontally shifted 2 right f(x-2).
My problem is/was I can't determine if it is a vertical or horizontal flip because square root of x cubed looks the same both ways. So I have an assumption, I would like to know if it's correct and a question.
It would have to be a vertical flip because a negative can be on the outside of a square root but not inside and still be a function?
Also if I come across this problem again, and the horizontal and vertical flip would both look the same what are some better ways of determining which it is?
The square root of x cubed looks like this [itex]\sqrt{x^3}[/itex] but I'm assuming what you meant to say is the cube root of x? [itex]\sqrt[3]{x}[/itex] Like that?
Not true. Since it's a cube root, you can have a negative inside of it with no complications.
For example, the cube root of negative 8 is negative two, and the cube root of positive 8 is positive 2.
It looks the same, because it IS the same. There is no difference between a horizontal and vertical flip (in this case)
To flip it horizontally, you replace x with negative x (because you want to 'flip' the x axis) and so you get [itex]f(x)=\sqrt[3]{-x}[/itex]
To flip it vertically you replace y (or "f(x)") with negative y (because you want to 'flip' the y axis) so you get [itex]f(x)=-\sqrt[3]{x}[/itex]
Let's compare those two functions.
Not only do they look the same visually (which is what is confusing you) but they ARE the same.
Look:
[itex]\sqrt[3]{-x}=\sqrt[3]{(-1)(x)}=\sqrt[3]{-1}\sqrt[3]{x}=-1\sqrt[3]{x}=-\sqrt[3]{x}[/itex]
So you see, it truly does not matter which way you do it. Not visually, and not mathematically.
This is very confusing. You wrote 3√x, which is 3 times the square root of x. You described this as the square root of x cubed, which could be either this --
$$\sqrt{x^3}$$
or this --
$$(\sqrt{x})^3$$
How you wrote it makes me think that you meant the cube root of x, which is ##\sqrt[3]{x}##. Which one is your problem?
The second graph is flipped, vertically shifted 1 up f(x)+ 1 and horizontally shifted 2 right f(x-2). My problem is/was I can't determine if it is a vertical or horizontal flip because square root of x cubed looks the same both ways. So I have an assumption, I would like to know if it's correct and a question.
What makes me even more certain that they meant [itex]\sqrt[3]{x}[/itex] is that they said (or implied) that the function is odd.
I did mean cube root of X
ty and sorry for the confusion
your comparison was very helpful ty
Where do I learn how to make the rest of the symbols, besides the 'Quick symbols' given
If you look at the top on the very right there's a sigma symbol [itex]\Sigma[/itex] which has a lot more symbols (it can sometimes be annoying to find what you're looking for at first)
A lot of them are simple though, and so if you use them enough you'll just type it out by hand
(for example, "x^2" gives you [itex]x^2[/itex])
awesome thanks again
