Floating Water Bridge and Dielectric Strength per Volume
The discussion centers on the floating water bridge experiment, specifically the electrostatic discharge observed before the water bridge forms. This discharge is attributed to the electrostatic breakdown of air between two beakers. The conversation shifts to the electrostatic breakdown of water, which is noted to be between 65-70 MV per meter. A key point clarified is that the measurement of breakdown is in volts per meter (V/m), which refers to the electric field strength and does not require a volume measurement. The example provided illustrates that if electrodes are placed 1 centimeter apart in water, the dielectric breakdown would indeed scale to approximately 650 kV, confirming the relationship between distance and voltage required for breakdown.
HelloCthulhu
I recently watched a great video demonstrating the floating water bridge experiment:
At around 34 sec, you can see an electrostatic discharge before the water bridge forms. I've read that this is due to the electrostatic breakdown of air between the two beakers.This made me curious about the electrostatic breakdown of water, which is listed on wiki as 65-70MV per meter. My question is, at what volume would this be true? If electrostatic breakdown is measured in volts/meter, would the volume be measured in cubic meters? Any help understanding this concept would be greatly appreciated!
Chemistry news on Phys.org
V/m is a measure of electric field: no volume required. So if you have two electrodes in water that are one meter apart, you need to apply 65 MV to get dielectric breakdown of the water.
Likes HelloCthulhu
Thank you so much for responding. Just to make sure I understand this correctly, I'll purpose this scenario. Let's say I fill a 1 cubic centimeter container with water and place electrodes on either side. With roughly a distance of 1 centimeter (0.01m) between the electrodes, would the dielectric breakdown of the water equal 600kV?
More like 650 kV, but yes, that's how it scales.
Likes HelloCthulhu
  • · Replies 32 ·
10K
11K
