Fluid Dynamics - Hydrostatic Pressure #2
4 replies · 2K views
Lukas_RSA
a Flat rectangular door in a mine is submerged from one side in water. The door dimensions are 2m high, 1m wide and the water level is 1.5m higher than the top of the door. The door has two hinges on the vertical edge, 160mm from each corner and a sliding bolt on the other side in the middle. Calculate the forces on the hinges and sliding bolt.
(Hint: consider the door from a side view and from a plan view respectively and take moments about a point each time.)
Answers: 8.327kN; 16.15kN; 24,525kN
i am able to calculate the pressure at the sliding bolt but i don't know how to approach the problem of the hinges, please help me to understand this concept.Sliding bolt:
Fsb = p(water density) g 'y A(door) / 2 'y = 2/2 + 1.5
= (1000)(9.81)(2.5)(2x1) / 2 'y = 2.5
= 24.525 kN
now i thought that to get the answer to the hinges you simply just change 'y to the desired distance, 'y = 1.5+ 0.160
and for the second hinge 'y = 1.5 + ( 2 - 0.160 )
the ansers i get is not correct, the textbook has these questions as excercises after each module.
i hope to hear from you soon.
regards
Lukas van Rooyen
= 24.525 kN
The hinges and the sliding bolt keep the water pressure from pushing the door our of its frame. The force on the hinges or the sliding bolt is not just ρgh * Adoor
Remember to use the Hint given in the Problem Statement.
thanks for the feedback
i tried all possible angles to tackles this problem but i cant, so if someone can help me and show me step by step with notes i would really appreciate it.
regards
Lukas
Realy
i am not asking for the answer i have the answer, i am asking to explain how to get to the answer i don't grasp the concept, shees what a hasstle for some help on this site, luckily i found CHEGG.com there i even speak to a tutor who explains to me the concept.
but yey well thanks for wasting my time, will not use this website again.
cheers
