How Do You Calculate Fluid Force on a Rotated Square Tank?
The discussion focuses on calculating the fluid force on a rotated square tank containing oil. The tank has a height and width of 12 feet and is filled with oil that has a weight-density of 57 lb/ft³. To express the fluid force when the oil is 4 feet deep, the formula f = pA is utilized, where pressure (p) and area (A) are functions that need to be defined. The setup of the definite integral for this calculation is the primary concern of the participants.
  • Understanding of fluid mechanics principles
  • Knowledge of definite integrals in calculus
  • Familiarity with pressure and area calculations
  • Concept of weight-density in fluids
  • Research how to derive pressure as a function of depth in fluids
  • Learn about calculating area for rotated shapes in fluid dynamics
  • Explore examples of fluid force calculations using definite integrals
  • Study the implications of weight-density on fluid force in various scenarios
Students and professionals in engineering, particularly those specializing in fluid mechanics, as well as mathematicians interested in applications of calculus in real-world scenarios.
tnutty
A metal oil tank has cross-section that is a square rotated 45 degrees as shown in the figure above. Its height is 12 ft and width is 12 feet. The oil in the tank has a weight-density of 57 lb/ft3.
Write a definite integral that expresses the fluid force on the end of the tank when the oil is 4 feet deep?
Here is a link to the photo :
http://img17.imageshack.us/img17/2294/76984288.jpg
hopefully you can make it out.
I am not sure how to set up the definite integral.
Well, I think you can figure out out that
f = pA
Right?
Area is a function that you have. Pressure is a function as well. What are these functions?
