Force components of two strings tied to a painting at 45 degree angles
The discussion centers on the equilibrium of two strings tied to a painting at 45-degree angles, focusing on the horizontal components of the forces involved. The key equation derived is Fnet = 0, leading to the conclusion that the horizontal components S1x and S2x of the forces exerted by the strings are equal, i.e., S1x = S2x. This equality arises because both components act away from the painting, ensuring equilibrium, rather than being equal and opposite as initially questioned. The confusion regarding the signs of the components is clarified, emphasizing the importance of directional assumptions in force analysis.
  • Understanding of static equilibrium principles
  • Knowledge of vector components in physics
  • Familiarity with force diagrams and free-body diagrams
  • Basic algebra for solving equations
  • Study the concept of static equilibrium in detail
  • Learn how to construct and analyze free-body diagrams
  • Explore vector addition and subtraction in physics
  • Review the principles of tension in strings and cables
Students in physics, particularly those studying mechanics, as well as educators and anyone involved in understanding forces in equilibrium scenarios.
Mr Davis 97
Find the equation of the horizontal components of two strings tied to a painting at 45 degree angles with the horizontal.
Fnet = 0
Since the painting is in equilibrium, I found that, in the horizontal direction, Fnet = 0 = S1x - S2x, where S1x S2x are the horizontal components of the force by the strings. What I don't understand is why S1x = S2x. This naturally follows as a result, but aren't these two quantities equal and opposite, since they have the same magnitude but are in opposing directions? Shouldn't it be S1x = -S2x?
The set up is not at all clear. Is the painting at 45 degrees or the strings? Where are the strings attached to the painting? Etc.
Fnet = 0What I don't understand is why S1x = S2x. This naturally follows as a result, but aren't these two quantities equal and opposite, since they have the same magnitude but are in opposing directions? Shouldn't it be S1x = -S2x?
you assumed that one comp acts left and the other right. The fact that s1= s2 means means you assumed the correct directions, provided, however, that each comp pulls away from the picture, not toward it. Plus and minus signs get very tricky.
