Force Couples - Computation of Forces
28 replies · 5K views
SandboxSgt
Hey folks, I'm rather stuck. I have a complete mental blank on this question. Having the force couple first has confused me I think
Compute the forece supported by the pin at C for the frame subjected to the 400-N.m couple
[PLAIN]http://sphotos.ak.fbcdn.net/hphotos-ak-snc3/hs549.snc3/30037_407472593600_532198600_4297857_5544101_n.jpg
No idea where to begin!
Welcome to PF!
Hi SandboxSgt! Welcome to PF! :smile:
I'm not sure I understand what's happening at A and E.
Is E not resting on anything, but supporting an unknown weight?
And is A rotating frictionlessly about an axle resting on a fixed surface? :confused:
If so, start by taking moments about a convenient point, to find the weight (in Newtons) supported at E. :smile:
Start by calculating the force reactions at A and E using the basic equilibrium equations. Then use free body diagrams of each member and show your attempt at a solution.
G'day tiny-tim,
A acts as a roller, so has only a vertical reactive force, E is a pin therefore both a vertical and horizonal force...
PhanthonJay, I am just not sure how to start that, if I have a Force Couple of 400N.m shown where it is, how do I translate that into something I can start to find the reactions at A and E.
ok, then do A first instead of E …
start by taking moments about a convenient point, to find the reaction at A
what do you get? :smile:
Morning Tim!
This is where I get confused, in a force couple isn't it a moment itself? So for A i get Sum M(a) = (400) + B(4) therefore A = 100N ?
SandboxSgt said:
Morning Tim!
Hi SandboxSgt! :smile:
I'm about to go to bed! :zzz:
That's correct … whichever point you take moments about, a couple always goes in as a pure moment, of the same amount. :smile:
I'm confused … what's B, and which point are you taking moments about? :confused:
ERrr E not B! #$#@ I'm so over this question, I saw it in my sleep last night!
And I realize I've gotten that wrong...
M(a) = (400) + E(4) therefore E = 100N
M(e) = (400 x 3) +A(4) therefore A = 300N
eek! you keep changing it! :redface:
No, one of E(4) and A(4) is wrong … moment isn't distance times force, it's distance cross force. :wink:
And where did 400 x 3 come from? :confused:
Goodnight! :zzz:
Haha Night Mate...
Thanks for your help.
God damnit, its a 100N each!
If I could show you the reams of paper I have here, it was the first answer I worked out, but thought... That can't be right!
tiny-tim, thanks for kicking my head into the right direction.
Now that you have E and A, you must indicate their direction. Now continue to find the forces supported by the pin at C.
Well after many reams of paper, I have the reactions but am no where near the Forces in C. I know the answer is 224N, but I seem to just push around the moment. Either I'm missing something obvious or I'm just really not getting it.
If I have the reactions of A being 100N Up and E being 100N down, what's the next step?
What I do is take 100/Cos 45 which is equal to 141.421, move up to C, time 141.421 x 2 as there are two arms, then multiply by sin45 and I get 200 again... I know it's wrong...
Or I take moments, and get 400 at a point 2m below C... #@$@#$@#$%^!
Morning SandboxSgt! :wink:
You need to use moments for each rod separately
Let the reaction force on rod CDE (from rod ABC) be x right and y up …
I'm not sure I understand...
My reactions are at point A and E, if I take moments about B for ABC I get C = 0N
If I take moments about D I get C = 0N
I'm missing this bit in the thought process. I believe there are no horizontal forces on any of the points as there is no externally applied horizontal force?
I assure you that I've done the problem myself (and got the correct answer, 224N), and there is a horizontal component.
Remember, if the reaction force on rod CDE (from rod ABC) is x right and y up, then the reaction force on rod ABC (from rod DEF) is x left and y down …
the internal forces always add to zero. :wink:
Thats the issue, I'm not sure how to get the reaction of one rod on the other...
Once I've worked out the reactions at A and E, does that mean the 400 is no longer touched or... I don't know...have spent close to 10 hours on this *cries* ;)
Just do what I said … split the reaction into x and y components, add the moments for ABC, to get 0, and add the moments for CDE, to get -400.
That will give you two equations for two unknowns (x and y).
Show us what you get. :smile:
Ok, so If I'm thinking right, I get the Y component of C to = 100 and the X component to = 200...
Where looks to be not right because it doesn't match up with what you just said...
uhh? that's what I get :smile:
how does it not match up? :confused:
Ok, here's what I did..
for ABC
Sum -> =0
BX = CX
Sum ^ = 0
So Cy = 100
Sum M (B) AC Pos +100-100-Cx = 0
Therefore -CX = 0
For CDE
Sum -> =0
DX = CX
Sum ^ = 0
So Cy = 100
Sum M (D) AC Pos 400-100+100-Cx = 0
Therefore CX = 400
Which is different to what I said above as for the above I didn't use the 400, and I was using the reactions directions not the force in the element
No, you've got pluses and minuses the wrong way round.
For example …
for ABC
Sum -> =0
BX = CX
Sum ^ = 0
So Cy = 100
… that should be Cy = -100 :wink:
(and it would help if you didn't use the same symbol, Cy, for two opposite forces)
Try again. :smile:
I'm getting sleepy :)
Right
for ABC
Sum ->+ =0
-BX-Cx=0
-Cx=BX
Sum ^+ = 0
-100+Cy=0
Cy=100
Sum(M)(b) AC+
100 + 100 + Cx = 0
Cx = -200
For CDE
Sum ->+ =0
DX+C'x=0
C'x=-Dx
Sum ^+ = 0
100-C'y=0
-C'y=-100
Sum(M)(d) AC+
400 + 100 + 100 - C'x = 0
-C'x = -600
Therefore Cy = 200 and CX = 400
So I sq 200 and 400
Which gives 160000 and 40000, which I add and sq.root
Which gives me 447.214...
And as that is a single resultant and it's all symetrical, I divide by 2 and get 223.6, which is close enough to 224 that I won't lose any sleep...
BOOOYAH!
Or did I make that last bit up :D
SandboxSgt said:
… I divide by 2 and get 223.6, which is close enough to 224 that I won't lose any sleep...
BOOOYAH!
'fraid so :redface:
you only divided by 2 because you knew it was twice too much.
SandboxSgt said:
… Sum(M)(b) AC+
100 + 100 + Cx = 0
Cx = -200
Sum(M)(d) AC+
-C'x = -600
I don't understand where either part of that last line comes from. :confused:
I thought you'd already found that Cy = 100?
And your equation 400 + 100 + 100 - C'x = 0 (which uses Cy = 100, doesn't it?) should be 400 - 100 - 100 - C'x = 0.
Right, here's my solution...
[PLAIN]http://sphotos.ak.fbcdn.net/hphotos-ak-snc3/hs261.snc3/27687_408007628600_532198600_4318550_8123271_n.jpg
Everything seems to marry up, I was adding the Cy to the C'y and the Cx to the C'x...
Have I stretched the truth with this one?
I think I need to subscribe to this site, atleast to cover the bandwidth this has eaten... :)
hmm …
i] I think you've drawn the arrows at A and E the wrong way round … isn't the force at A on ABC up?
ii] you don't need to use C' for CDE … since your diagram shows the opposite directions for the arrows, you can use the same names for CDE as for ABC, Cx and Cy (which has the advantage that it will make the two equations compatible)
iii] you can't assume that the forces at B and D are purely horizontal … that's why it's best to avoid that problem by taking moments about B and D :wink:
iv] your moments equation for CDE must include the 400N torque, since that is applied to CDE (though not to ABC)
hmm …
Argh, I thought I'd put this to rest...
If i put 400 in CDE, i don't get -200 or is that purely because my arrows are wrong...
Your arrows for ABC should be 100 up at A, Cx left and Cy down.
Your arrows for CDE should be 100 down at A, Cx right and Cy up. :smile:
